What to use to flush, clean an old hydraulic reservoir and system
   / What to use to flush, clean an old hydraulic reservoir and system #1
lhfarm
Central Indiana
NH TC40DA
In my continuing quest to get our antique hydraulic lift for our jeep working, I want to clean 60 years of stuff from the reservoir, control and pump. Need suggestions for cleaning fluid and flushing process. Suggestions?
Thanks,
Barry
   / What to use to flush, clean an old hydraulic reservoir and system #2
clean and push out as much as you can, blow out with compressed air ect. get the cheapest oil with high detergent that you can find IE 10wt motor oil, dextron trans fluid, hyd oil and run the system. If is on a Jeep there cant be much in it, is there? then dump and do over. How do you know if the pump is any good, have you tested it? CJ
   / What to use to flush, clean an old hydraulic reservoir and system #4
I'd do what CJONE said but I'd use diesel for the flush fluid....Mike
   / What to use to flush, clean an old hydraulic reservoir and system #5
Good advice imo, for a small system this should be quick and cheap and should serve your needs well.
   / What to use to flush, clean an old hydraulic reservoir and system #6
I thought about diesel but he wants to run the system with it in and with a small res it would be hard to get it back out. I am also not a fan of actually running the system with diesel either, I will not run a system with it in. I will preflush hydrostat hose systems with diesel then remove as much as I can [almost 100%] before system startup. CJ
JCB 2145 (A47477)
JCB 2145 (A47477)
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
UNUSED FUTURE FT13CJ EXCAVATOR (A57192)
UNUSED FUTURE...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2006 KAWASAKI MULE 3010 DSL UTV (A57192)
2006 KAWASAKI MULE...
