What to use in my B7100 transmission
   / What to use in my B7100 transmission #1
NewClimber
Kalama, Washington
B7100D
I have a 1977 B7100 with a manually transmission, when I bought the tractor, the guy even had the original owners manual. It say to use SAE80 oil for the transmission/hydraulics.
A dealer I went to for the first time, told me that this is UTF fluid, the same I use for the FEL? Is this correct? I know that the transmission fluid is also the hydraulic fluid for the 3 point lift. Just want to make sure I was not getting bad advice from my local dealer..
   / What to use in my B7100 transmission #2
That is what I used in mine, I have the same tractor 1978 model. The reservoir is for the trans, FEL, & 3 PT hitch.
   / What to use in my B7100 transmission #3
I would have to agree that UTF is what you should use. In addition to being a hydraulic oil UTF is also designed to be a gear lubricant.
   / What to use in my B7100 transmission #4
Yup, just hydro fluid. We get the stuff by the 55 gallon drum at work - none of this fancy shcmancy Kubota only brand stuff.
(For far more in depth discussions of the different types of oil there is a forum dedicated to Those That Believe...)
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
2021 JOHN DEERE 6130R LOT NUMBER 171 (A53084)
2021 JOHN DEERE...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
(INOP) CATERPILLAR IT-38G LOADER (A51247)
(INOP) CATERPILLAR...
