What to use in my B7100 transmission
   / What to use in my B7100 transmission #1
NewClimber
Bronze Member
Kalama, Washington
B7100D
I have a 1977 B7100 with a manually transmission, when I bought the tractor, the guy even had the original owners manual. It say to use SAE80 oil for the transmission/hydraulics.
A dealer I went to for the first time, told me that this is UTF fluid, the same I use for the FEL? Is this correct? I know that the transmission fluid is also the hydraulic fluid for the 3 point lift. Just want to make sure I was not getting bad advice from my local dealer..
   / What to use in my B7100 transmission #2
That is what I used in mine, I have the same tractor 1978 model. The reservoir is for the trans, FEL, & 3 PT hitch.
   / What to use in my B7100 transmission #3
I would have to agree that UTF is what you should use. In addition to being a hydraulic oil UTF is also designed to be a gear lubricant.
   / What to use in my B7100 transmission #4
Yup, just hydro fluid. We get the stuff by the 55 gallon drum at work - none of this fancy shcmancy Kubota only brand stuff.
(For far more in depth discussions of the different types of oil there is a forum dedicated to Those That Believe...)
40' CONTAINER (A51248)
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
(1) WHIRLPOOL REFRIGERATOR (A51248)
(1) WHIRLPOOL...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
