What to use for a level indicator for forks?
   / What to use for a level indicator for forks? #11
Slow down.
Generally I look at the fork tips. The only time I break pallets is if they are frozen to the ground in winter or I am or the pallets are on uneven ground and one fork is sitting higher.
If your pallets are stacked level then any other breakage is usually due to operator error.
   / What to use for a level indicator for forks? #12
   / What to use for a level indicator for forks? #13
On my B7800 I'd just stand up and look over (I used 3pt forks chained to my bucket- yeah, cheesy, but it worked). My Kioti NX and the cab is a different story...
Aggravating for those that do not have a clear view. It's for this reason I installed a camera system in my NX. Unfortunately I have yet to install a replacement camera after blitzing my first one: I'm trying to come up with a reasonable design that allows me to be able to move the camera around while still protecting the camera- I am close to a solution, but have yet to prove it out (doesn't require welding as I do not have a welder, so I'm a bit handicapped/limited).
   / What to use for a level indicator for forks? #14
I'll add that it's not just whether the works are "level," but that they're correctly positioned. Lots of times having a slight drop in the tips is warranted, in which case "level" isn't of much help.
I operate on uneven ground. While I might be honest I'm certainly not operating on the level!:laughing:
   / What to use for a level indicator for forks? #15
Any low cost back up camera system would be the most cost effective IMO.
As suggested U could mount the camera on a magnet base.
With a camera system you would be able to work on all sort of uneven ground situations.
Many of the back up systems can take 2 camera inputs and the ones I am familiar with have options for front/back and flipping of image.
Also wireless or wired options exist but always the camera wants DC power.
One downside is the wireing is of such a small gauge that U need some sort of protection for a tractor environment.
I am using a $50 ish offshore system for slightly over 3 years now with no problems, mainly for snow blowing duties.
I used magnets for my mounting and placed the viewer low center of my windshield.
If not urgent EBay and AliBabba are good sources.
   / What to use for a level indicator for forks? #16
^^^ And you inspired me on this. I went with a nice magnetic base, as that allowed me to move the camera around. The magnet I had was really strong and the camera's thin metal attachment base not so strong. But for those that are more careful (I think I bliitzed mine removing snow out on our local road) it's the best solution.
   / What to use for a level indicator for forks? #17
I would love to have one of those camera set-ups. One pointed rear to watch 3pt work, and one pointed at the QA implement.
   / What to use for a level indicator for forks? #18
Not sure what brand my forks are but, the SSQA design makes my forks level when my indicator shows level.
Still a pain if on uneven terrain. If I tip my forks up a bit I can see the ends. Soon as I level them they are gone...
   / What to use for a level indicator for forks? #19
I have HD mercury switches I was always gonna make something out of. If someone made a wireless magnetic sensor that indicated degrees to a good resolution, that would be sweet!
   / What to use for a level indicator for forks? #20
If you mistreat your pallets, they may run off and hide in some far off field ...............
Year: 2015 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 137,900 Plate: Body Type: 4 (A56858)
Year: 2015 Make...
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
UNUSED FUTURE FT36C STAND ON SKID STEER (A57192)
UNUSED FUTURE...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
