What to use for a grill grate?
   / What to use for a grill grate? #1
Haywire
Central Kentucky
Tractorless :(
I'm still forming ideas for the grill I want to make. what are you guys using for a grate to put the meat on? I have a piece of expanded metal, but it isn't the flat kind, which would make it hard to clean.
After finding a 20lb tank, I have decided that it's a bit too small, even for just my wife and I. I'm looking for a 40lb tank. A piece of square pipe about 24" long and 12" in diameter would be ideal.
Ian
   / What to use for a grill grate? #3
That floor grating is good for what you need. I would splurge and get the stainless steel version. I liked the one shaped like little I-beam. I never saw anything like that, usually it is just the welded flat bar type.
   / What to use for a grill grate? #4
If you want a really nice grill try a restaurant supply. Restaurant stoves use cast iron and they are heavy. They come in pieces that fit together to make the grill so they don't weigh 200 pounds. You want a heavy grill so that when you throw the steak on it sears it without going cold like a thin grill does. Nothing you see in a barbeque store is anything like the real thing, especially those ones with the porcelain on them.
Joe H
Like these http://www.o-reps.com/id177.html
   / What to use for a grill grate? #5
Re-bar makes a good grill. 3/8" is a good size. Have made them for grills, smokers and wood stoves. Cheep & easy. :D
   / What to use for a grill grate? #6
I was thinking of using 1/4 or 3/8" square bar for my next grill.
That's what I was thinking about, but stainless. Square would be easier to weld together than round stock. Don't want to get too deep in the wallet though, so it's probably not gonna happen.
Ian
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
SYSTEM ONE 102 DEGREES PARTS WASHER (A51248)
SYSTEM ONE 102...
Kenmore KLFC015MWD0 Deep Freezer (A53117)
Kenmore...
2011 KMC 3376 LOT IDENTIFIER 244 (A53084)
2011 KMC 3376 LOT...
2021 CATERPILLAR 420XE BACKHOE (A51246)
2021 CATERPILLAR...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
