What to "paint" 1/2" OSB with for exterior use?
   / What to "paint" 1/2" OSB with for exterior use? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've read several threads on here, but didn't see anything recent.
Background - I've got a bunch of "cut-offs" (~4'x~5') that I want to make into small sheds/tool boxes to put about my properties. Primary purpose is short term tool/material storage due to inclement weather, and it's Mississippi so it inclements a lot.
I'm trying a 2 coats of WHOOPS latex and also going to try 1 coat of primer and 1 coat of latex. ALL edges coated.
But I'm open to suggestions to anything that would be better/cheaper.
* WHOOPS paint is the stuff you find at the hardware store for $3 to $5/gallon because someone returned a tinted can
now it's more like $15/gallon :(
   / What to "paint" 1/2" OSB with for exterior use? #2
For exterior use with OSB a primer is always recommended to be applied before painting.
   / What to "paint" 1/2" OSB with for exterior use? #3
Primed and two coats of latex on my box stands in Mississippi. 15 years and looking good.
   / What to "paint" 1/2" OSB with for exterior use? #4
+1 on coating all the edges.
Are these use and replace items? Around here OSB doesn't fare very well in the weather, and I would have expected Mississippi to be much worse. Are you going to put anything over it? Tyvek, siding, or something that is exterior rated?
All the best,
Peter
I'd like to get 5 or 10 years out of them. I have had OSB that wouldn't last the truck ride home, and had some Advantech that lasted outside for years.
I'm mainly just checking the TBN knowledge base to make sure there's nothing new on the market. I greatly dislike finishing a project the best way I can, only to find out there was a much better way for the same resources.
Normally I disdain OSB for anything, but this was like $20 for the equivalent of 6 4x8 sheets, delivered.
   / What to "paint" 1/2" OSB with for exterior use? #6
I used OSB to cover a bunch of barn windows about 10 years ago, never painted it and it has held up very well.
   / What to "paint" 1/2" OSB with for exterior use? #7
A relative of mine built and painted a 12x16 shed sided with OSB in the early 80's. He gave it an oil based prime coat and two latex top coats. All brushed on using Sherman Williams top of the line paint.
It's still there but under different ownership since about 1990.
   / What to "paint" 1/2" OSB with for exterior use? #8
I've had good luck with used motor oil. Roll it on until it won't absorb anymore.
   / What to "paint" 1/2" OSB with for exterior use? #9
All the best,
Peter
OSB is not made to be left outdoors exposed to weather. Weather its painted or not.
   / What to "paint" 1/2" OSB with for exterior use? #10
Personally, much as I generally like latex, I would consider using oil based primer and oil based paint on the OSB for the reasons that @ArlyA points out, I.e. the glue is not water resistant.
Hence, my question about whether these were disposable sheds.
All the best,
Peter
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
Freightliner Tender Truck - Adams Tender (A55315)
Freightliner...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55314)
PENDING SELLER...
2016 Club Car Precedent Electric Golf Cart (A53424)
2016 Club Car...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
