What to look for when buying a used excavator?
   / What to look for when buying a used excavator? #1
future_vision
New England
DK6010SE HSA
I'm looking at buying a used excavator. It'll likely be an older, high hour excavator since I don't have a large budget. What should I look for? Are there any particular repairs I should stay away from? Any other telltale signs of an excavator that hasn't been taking care of?
   / What to look for when buying a used excavator? #2
Take someone with you that knows how to operate one.
Big things to look at
1. under carriage
2. pins/bushings (slop in the booms/buckets)
3. cylinders and hoses. Look for aged hoses that are soon to need replaced, and look at the cylinders....do they leak? Rods all scored/scratched, or rusted.
If it starts, runs well, and is tight with little to no slop, and dont leak any fluids it should be a good machine
   / What to look for when buying a used excavator? #3
Older and higher hour can me many things to many people. But generaly you need to inspect the hoses, bucket and arm pins along with track condition. Of corse general engine things also.
One thing to look for in a excavator is leaks from the center hydraulic pivot. This can be a major job and very costly.
I bought a micro ex about 4yrs ago with 1584hrs. It's a kubota kh41, 3500lb machine built in Japan in 1990. Yes it's small but I have put on 400hrs with no issues. Havent even put a set of rubber tracks on it.
Some people may think that a 3,500lb machine is to small to dig a septic system or dig out a foundation of a alreaty built house and there kind of right..but I have done all that and I live on clay and bed rock. All it takes is some extra time and diesel.
   / What to look for when buying a used excavator? #4
If you have any interest in driving to Southeastern Connecticut, I can show you mine. The good, the bad, and the ugly. Or if you have a buddy that has one, I think looking over one in person will be far more valuable to you than trying to describe online.
I bought a 1992 Hitachi 120, with about 4500 hours about a year ago. We are someday building a house on property up the street, with about 1/4 mile of driveway to put in.
We replaced the track chains on it, which was about 5k in parts and I did the work myself. I knew they were worn when I got it, and they could've been pushed more, but I wanted to drive it up the road to the new place, and the peace of mind was worth it. It drives and turns far smoother now.
We looked at this machine, and also a Deere 690D. The Deere was a larger machine, which was intimidating to me in the event of a failure. On my 120, I could pull the motor if I really needed to using my tractor. No chance on the Deere. Also a hydraulic pump for the Deere was something in the range of 10K, and they were known to fail.
We've been able to do a tremendous amount with the 120, and working in the woods where we are, I wouldn't want anything much bigger. So independent of condition, picking out the appropriate size machine is something you'll need to contemplate.
If you are looking older and higher hours, you're going to run in to worn pins, leaky pistons, old hoses, faded paint, some dents etc. None of those is likely a deal breaker. What you're looking for in a machine will probably be different than someone looking to make a living with it.
I'd check track chains for stretch and ensure the correct number of links, look for really bad leaks, look at the coolant, oil, and hydraulic fluid for color and contamination. Try to start it cold if possible, pick up the machine to check play in the swing bearing. Check the swing gearbox to make sure it has gear oil in it, and hasn't been packed with grease. Run it to make sure it operates smoothly and has power.
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
2015 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-65...
Pick up bed (A55973)
2007 International 4200 S/A Chipper Truck (A56858)
2007 International...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
