What to look for in used 4120
   / What to look for in used 4120 #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Any major flaws with a 2010 4120 hst?
If not, what should I look for on one with 750h?
What's a good price? No fel, not attachments.
   / What to look for in used 4120 #2
The JD4120 is built like a tank. And the weight of 4000-lbs with the machine does reflect that too. Lots of heavy duty casted parts as well. A big and heavy engine in a small package.
If your concern is about the weight, the 3xxx series has the 3046R that can hold it's own as well.
The real concern is, parts availability and costs. The true JD made in house engine is more unique and custom. Years from now, those parts will be a premium. IF you picked a JD with a Yanmar engine, parts are more popular in the aftermarket channels right up to full engine repower replacements.
So, if your looking to have a tractor for life, be sure to know what you are getting into.
Thanks. Is "tank" here a good thing? Generally I would want that. I have a 4100 cut and don't like the newer 20hp light weight models. The proprietary parts does sound concerning. Is that engine likely to go 4K hours? The one for sale here has 750.
   / What to look for in used 4120 #4
Tank is a good thing for a solid strong machine. It's bad when you are in areas requiring a weight limit like crossing a home made creek bridge or driving next to a septic field. Also bad when it's sloppy outside going down hill.
I know the Yanmars go for several K hours before an overhaul. Some even out into the 6K to 12K hours. Depends on the use and abuse.
I understood you that the 4120 is not a yanmar. Thoughts on it's longevity?
   / What to look for in used 4120 #6
Call JD and ask what the design life of the engine is.
Is there high confidence JD design life is a good measure?
   / What to look for in used 4120 #8
Unknown. I've only owned JD machines with Yanmar engines, and now a Yanmar with a Yanmar engine.
Some, not all JD engines are used in other industries like Industrial and Marine. Should the 4120 engine have the same offerings, then it would be good to buy. This way, parts would be available for a mighty long time.
As the saying goes, don't be drawn in by the one-offs. You'll pay thru the nose in the long run.
   / What to look for in used 4120 #9
I own a 4120 hat and I love it . Have grapple, bucket, forks. Use it all the time.I also have tiller, disk, spike tooth harrow, three pt spreader and MX 6 clipper from Deere. I did not want the yanmar, engine and wanted it built in USA. Mine has the Power Tech engine and the tractor was made in Augusta GA and wanted the three tier and not the four so it does not have the burn off feature which is what I wanted and got it the last year they built the three tier. Love it. Also my friend got the one that replaced it and lot of changes. The pedals are not heavy like on the 4120, mine are made out of same material like in the bigger tractors not flimsy like the ones they put on now.
   / What to look for in used 4120 #10
Well, some of the engines were made US side and the rest in Mexico. And the PowerTech engines are very unique to themselves, thus, there really isn't any part interchangeability amongst engines. The engines are extremely proprietary. The 4120 was made only for 10 years and today has a totally different replacement. hmmmm
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
Rooster Weathervane (A55853)
Rooster...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
1989 Hyster H40-XL-MIL 4,000lb Diesel Forklift (A55851)
1989 Hyster...
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
