what to go with a snow plow mount?
   / what to go with a snow plow mount? #1
ky billhilly
In the hills of west Ky.
B series Kubota's
Hello all, I've recently purchased a Kubota B7100 4wd gear driven (not hst)tractor. it came with a bush hog, a grader blade and a complete snow plow with 3 cyl. for l,r and up down. the blade while intact, is mangled, was formerly owned by a nearby small town and will be reconstructed. what i would like to do is also use it to use with other attachments of some sort....but what???? the sub frame is still on the tractor, the blade mount and hyd valves are currently off. i need ideas folks! this is my first non-red tractor, i've been a farmall guy for a long time.
thx, tim in western ky.
   / what to go with a snow plow mount? #2
Do what my dad did with his massey. He took the frame work off the bushhog and use the A part of frame and connected it to his fisher plow. all he had to do was add a 2.5 foot angle bar from a frame to top of plow. He would clear snow in forward and backward direction with no problem. I thought of doing the same thing but the meyers plow I got fit pretty good on the BX fel arms with quick hitch pins after I removed the A arms off. These picture are old but it would give you an idea.
Well good idea but I really wanted to retain the useability of the originial snow plow. I was just hoping that some of these super intelligent folks could come up with an attachment for it, like a super spade or....
ideas anyone??
tim
   / what to go with a snow plow mount? #4
Can you post some pics to give a better idea what there is to work with, also the real queston is what do want to do, a toy is always better for having a purpose
   / what to go with a snow plow mount? #5
KY, like bassgrinder said a picture of the sub frame would give up a better idea of the lift avaliable, but some possibilities would be a scoop bucket, a implement similar to the rachet rake (over in the Kubota section), a dethacher, a front receiver hitch. The possibilities are many, it depends what you might need.
Harley
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
1604 (A57192)
1604 (A57192)
3 HOLE FOOD WARMER (A58374)
3 HOLE FOOD WARMER...
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
