WHAT TO GET
/ WHAT TO GET #1
fredflintstone
michigan
cub cadet LS4140
howdy ALL. I am in a bit of a quandary on what 3pt attachment to get need something to move dirt, gravel and
probly some roots, now im considering a box blade or scraper blade or a landscape rake all have there marets
but not buying all three so looking for opinions on what more experienced tractor guroos think. Thanks for your input
/ WHAT TO GET #2
I would say box blade or rock rake/ landscape rake. I have Both for my tractors and they both have their different uses.
Landscape or Rock Rake:
- moving large rocks in fields
- moving large rocks to save your mowers
- raking up SOME roots of trees (they have to be pretty big)
Box Blade:
- Grading Driveways and roads
- Grading parts of your landscape
- Moving Snow
- Moving Roots
- Moving small to medium sized rocks
- Moving gravel to add to surfaces
- smoothing creek beds
- ripping up lawn
- ripping out small roots
- maintaining bonfires
- (weld d-rings on the back) use as log skidder
- MANY OTHER USES
Overall, I would buy a box blade. King Kutter and Landpride both make excellent box blades. I would opt for the higher dollar models that have easily removable teeth on the front/inside and have a cutter blade on the back. The back blade works great for maintaining brush fires and pushing snow and also pushing back gravel, mulch and/or rock piles.
Box Blades have far many more functions and you don't have to mess with angling the rake in certain spots and fixing it. Angling back and forth becomes such a pain in the ***. On and off, on and off, on and off of the tractor. Box Blades also can do the job of a log skidder which is very helpful because you don't need to try to drive backwards and mess with the loader.
/ WHAT TO GET #3
I have medium duty ,box blade,rear blade and York rake.Rear blade is mostly used for snow removal,the box blade for road maintenance(most versatile),York rake is nice for leveling.If I could have only one it would be the box blade.
/ WHAT TO GET #4
box blade is good choice for moving dirt gravel etc. just make sure you get the right size for your tractor as one that is too big will stall tractor
/ WHAT TO GET #5
For the tasks you have listed, and assuming you will be getting only one implement, the box blade is likely your best bet - will move the gravel and dirt and will handle small roots.
/ WHAT TO GET #6
Box Blades are one of the most common Three Point Hitch implements used as COUNTERBALANCE to the FEL.
If you have an FEL + bucket calculate your counterbalance needs and order an appropriately heavy Box Blade. If your rear tractor tires are liquid filled, you will require somewhat less counterbalance than if your rear tires are filled only with air.
Do you have two tractors? A Cub Cadet AND an LS?
/ WHAT TO GET
thanks for your replys looks like im leaning towards a box blade, my father inlaw loves his landscape rake. but a 5'
is to small for my tractor so we don't do much swaping attachments
2022 EZ-GO ELITE...
New/Unused Electric Winch (A65583)
New/Unused...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
Sakai SW354 (A60462)
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2004 John Deere 4720 (A60462)
2004 John Deere...
