What to do?
/ What to do? #41
Re: Proofmeter
Jim, I sit here and wonder if somehow your thinking that because your manual tells you that it records time at 1 hour @ 1833 RPM, with no rhyme or reason as to why, that somehow you have some great information. I can understand how PTO RPM might be considered as a index point. 1833 RPM sounds like the third harmonic when using 611 RPM as the transmoidal stoichometric tridescent cord, but other then that, is there any further explaination? I do know that Kubota L4850, International 454D and Ford 2120 are not based on the hourmeter time, but never really cared. I don't know the compression ratio, the idle fuel ratio nor the maximum RPM fuel ratio, the manuals I have seen never indicate that. Perhaps its because its really not important. I do suspect though, that they are correct. This is a double edged sword issue as a meter that posts time "faster" as yours apparently does, also means that the manufactuer wants you doing maintenance on it sooner leading one to beleive they have less faith in their product. I will have to agree with Hawgee, the hours on your meter mean something just as the miles on a car odometer. But would you really want to be buying a car from a teenager. I suspect what is was doing and how it was operated would be far more important then the miles on it. Rat...
/ What to do? #42
Re: Proofmeter
Hay Rat is that real thattransmoidal stoichometric tridescent cord or are you just funnin Jim on that?
If it is real what the heck is it or does it mean?
Gordon
/ What to do? #43
Re: Proofmeter
Oh yeah, Jim and I both did our BS research on this very topic. Jim expanded on this phenom right after I published my thesis on it. Jims assesment deviates from mine only where the third harmonic intersects and crosses the extrapolated indices formed by thembotical vertices. Jims conclusion was that BLUE was best, my conclusion was "Who Cares!" Thats about it in a nutshell. Rat...
/ What to do? #44
Re: Proofmeter
Speaking of nutshells, I missed Indy with the colt and barn chores over the week end. If we borrowed from these new $$$$$ race cars and had the black box that was recording, with telemetry back to the desktop..... Ya follow? We could chart the entire work session from the time you left the pits, I mean barn, or garage. We would have start time, RPM, water temp, wieght of operator, brand of oil in pan, air pressure in each tire, ground speed, wind direction and velocity, so on and so on. Talk about your truth in milage laws, we couldn't hide anything. We could borrow from the log trucks and the bunk scales to measure the load on the hitch. This is one proof meter I DON'T want. /w3tcompact/icons/wink.gif
I'm glad we wouldn't have to spend the bucks on wind tunnel testing. /w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ What to do? #45
Re: Proofmeter
tbarber55,
You are a MAN of courage! To state that on an Orange dominated board when you own both Blue and Orange! You Da Man! /w3tcompact/icons/cool.gif
JimBinMI
We boys and our toys!
/ What to do? #46
Re: Proofmeter
Rat,
I just think that knowing is better than not knowing! Knowledge is power, ya know!
Oh, smooth answer to Gordon...you going to answer his question or not?
JimBinMI
/ What to do? #47
Re: Proofmeter
Jim, get real, it takes no courage to make silly comments, even easier to ignore them when they are so biased its transparent. Rat...
/ What to do? #48
Re: Proofmeter
Oh Jim, what am I going to do with you. If knowledge is power, then it only stands to reason that a lack of it is dangerous. So again what is significant about 1833, just really curious, you and I could benefit from this knowledge I'm sure. Airplanes use crusing RPM as the basis for time on the Hobbs meter. Anything less then that, you record less engine time. No where is an industry more watchful of what equipment practices go on then in aviation. At 2000 hours, if your plane calls for an engine overhaul, your either doing it, or your not flying. Now all I need to do is go buy a Kubota and settle once and for all the issue of time/recorded on their tractors. Dang, I was all set to get a TC45D but you just had to poofmeter us.
P.S. still can't get any detailed specs on the TC45D, things like lift max on 3pt. at 2' behind pivot, or raising height of loader, hour meter recording method. Guess its like no knowledege, NO POWER.
PS. PS. James, I'm only kidding, I'd take your TC45D with SuperSteer anytime. Rat...
/ What to do? #49
Re: Proofmeter
Paddock
I can be biased since I own both brands. Both are great tractors I just like NH better,you won`t see me selling the Kubota to but another NH im not brand loyal.
You buy what you like Ford,Chevy,Dodge,Nissan,Toyota or what ever. I don't realy care what the other guy thinks,I get what I like..........................
/ What to do? #50
Re: Proofmeter
tbarber, Its better to be OBJECTIVE then biased. When you state your Kubota tractor has 900 hours on the meter and mention it looks like its got 9000, that may be true, but I'll bet you most people here would say its not the tractors fault, its the owners.(Jim being the exception) I have none of the 3 colors of tractors here (International 454) but use 2 of the 3 dominate ones for work (I also do all the maintenance on them). Orange L4850 and Blue 2120. I will tell someone what I like about both brands though. Even mention something terribly wrong (neither tractor has that problem). I'll bet a pile of dirt moved with a Kubota looks no different then one moved with a New Holland. Since I'm looking for a new tractor currently, its funny to see how flag waving people get. Jim is probably the king here, but I also know he is being somewhat comical in his posts (he's also kinda the loner). If that was your attitude and I took it to serious then I humbley apologize. Rat...
/ What to do? #51
Re: Proofmeter
Rat,
If he's being serious, what's wrong with that? He owns a NH and a Kubota and if he likes one better than the other, what's wrong? I would think that would be the ultimate objectivity!
JimBinMI
/ What to do? #52
Re: Proofmeter
Jim and Rat
I like both, I didn't mean to start a war over it.Can we move on to something else now ?
Id add some smiley faces but don't know how.Some help here please.
/ What to do? #53
Re: Proofmeter
tbarber55,
Click on "Instructions" at the top, the directions are in there. Hope Paddock will be OK! /w3tcompact/icons/cool.gif
JimBinMI
/ What to do? #54
Re: Proofmeter
tbarber,
When writing a message, click on the underlined line that says markup in your posts. The instructions are there and easy. Simply put the word smile inside of square brackets [ ] and it will look like this /w3tcompact/icons/smile.gif. Same works for frown and laugh and several others.
It is always interesting that people like their own tractors. Start worrying when someone DOES NOT. /w3tcompact/icons/smile.gif
/ What to do? #55
Re: Proofmeter
Or click on "FAQ", scroll down to "Can I use HTML in my posts?" and read about using Markup./w3tcompact/icons/smile.gif
Bird
/ What to do? #56
Re: Markup
Bird,
Thanks, I never used markup before in all of those posts that I wrote! Watch out guys...the <font color=blue>Blue</font color=blue> guy has more tools now! /w3tcompact/icons/cool.gif
JimBinMI
/ What to do? #57
Re: Markup
I sure am glad some of you guys buy those <font color=blue>blue</font color=blue> and <font color=green>green</font color=green> tractors. If it weren't for the competition, the good tractors <font color=orange>orange</font color=orange>, of course, would probably go up in price./w3tcompact/icons/laugh.gif
Bird
/ What to do? #58
Re: Markup
Bird,
They're already up in price...what are you talking about?
<font color=blue>BLUE RULES!</font color=blue>/w3tcompact/icons/cool.gif
JimBinMI
/ What to do? #59
Re: Proofmeter
Jim, I think the point of this went over your head, I was trying to point out to thbarber what he might have meant to say he can be more "objective" in his review, not more "biased", as a teacher, I thought you would have picked up on that right away. I'll try to be less subtle in the future. I of course owning neither but having many hundreds of hours between the two, must therefore have ultimate ability to be biased, hmmm, no, let me correct that "ultimate objectivity". (That was a joke) I am still thinking about this TC45D, but your trying to sell New Holland so hard, it makes me think something is wrong that it cannot sell itself (semi-joking here). Anyway, I must tell thbarber, its OK, I'll be alright. Brand schmand, I don't care about no stinkin brand. I don't take this stuff serious, its kinda fun though to see what makes different people tick. Its kinda like when I went to a photography web site and everything was Canon vs Nikon vs Minolta and everybody touted their brand as best to buy, but nobody would show their pictures. I thought then and still do now that when someone epitomizes the virtues of their purchase in a less then an objective way, their bias leads me to believe they are trying hard to convince themselves that they made the right choices. OK enough said about "proofmeters", now lets talk about oil, Amsoil. Is it any good and should I ...(joking yet again) Rat...
/ What to do? #60
Re: Proofmeter (serious)
One more thing JimBin from Michigin with a TC18'n (read this like your mad, jaw clenched)
You want serious?, OK, heres serious...
You just try and make me mad, upset me buddy boy, I'll have you know Mister Blue Bell Cacol(sp?) Shell, I Know Karate, Kung Fu, Kung Pao, Tsing Tao, and a couple more Chinese words, just you come to California and I'll prove it. (I'm not joking!) Rat...
P.S. You can even bring thbarber with you. Then I'll have 2 BLUE bellied lizard pooh ball butts to Tsing Tao on, wait, thats a beer I think.
"Can't We All Jis Git Along" Rodney King, circa 1990's
(Bird, thought you might like my new slogan)
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
2018 CATERPILLAR CB66B DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
