what to do?
   / what to do?
That looks very close to the tractor. It does have a canopy already, and from what I remember as a kid it always has. All the tires are flat and would have to be replaced. After sitting for so long, do I even dare to try ro crank? My old Ford had sat for a few years. After i got the red wasps out and a hot battery it fired right up and runs pretty good. Its just alittle lite for some of the tasks I need it for. Thanks for the photos. You have a nice lookin tractor!
   / what to do?
Jenkinsph, is that an i.d. tag rite there on the rite side above the front axle in your picture? If it is then I will know where to go look for some information.
   / what to do? #13
Yes, the id tag is what you are seeing above the axle.
   / what to do? #14
About the engine, if it has been setting for several years I don't think it would be wise to turn it over without pulling injectors and oiling the cylinders first. I would want to turn the engine by hand before using the starter. It would also be a good idea to verify that the clutch isn't stuck too, there is an inspection plate on the left side to see inside the clutch housing.
What happened to the tractor to allow it to sit without use? That would be my first question.
FWIW, I paid $3500 for mine back in '97 with a bad clutch, sunburned paint and cracked tires. Only 1200+ hours on the machine and very little detectable wear on hitch and drawbar. The prior owner was ill for some time and this tractor simply sat outside in the weather with only occasional use.
i split the tractor and installed a new clutch kit and waterpump kit, rode it to the tire shop and put new tires on it. A few months later I took it apart and reworked it with new battery, steering wheel, new lighting and wiring harness (home made) cleaned and painted everything after taking apart then reassembled. Looked brand new and I was very happy with it. With everything all totaled I have spent about $7000 on it and have used it for 14 years now, I am very satisfied with the cost/use ratio so far.
   / what to do?
Thanks for the information. I plan to stop by there again if not today, one day next week. I will let yall know what comes of it. I guess I could show back up at his house with a trailer and a come-a-long and some cash, he probably wont refuse!
PALLET OF IRRIGATION PUMPS / WATER PUMPS (A51244)
PALLET OF...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
