What to do with dam (pond) silt
   / What to do with dam (pond) silt #1
njrqs
Queensland, Australia
Kubota L1-20 DT
Hello all.
Had my dam (pond to you yanks) cleaned out last week.
It was almost empty and was full of sloppy silt.
I now have tonnes of the stuff lying around and as the ground around here is so crappy, I wonder if I can use this for garden beds.
The local council gave me truckloads of soil they cleaned out of the roadside gullies and plants thrive in it.
I wonder it my goo is really any different to that stuff. After all it too is run-off.
At the moment it is the consistency of grease and just as hard to get off things.
Once it dries, do you think it will be any good or will it always be horrible stuff.
Pic attached.
Ooops, here is the pics (Also refer my stuck-in-the-mud post under PHOTOS)
Cheers
   / What to do with dam (pond) silt #3
<font color=blue>I now have tonnes of the stuff lying around and as the ground around here is so crappy, I wonder if I can use this for garden beds.</font color=blue>
Silt or runoff is what makes most river valleys very fertile. I would think it would be just the thing for a garden.
   / What to do with dam (pond) silt #4
It should be good stuff. Try it in a flower bed for a test.
   / What to do with dam (pond) silt #5
If it's real greasy/sticky and can be rolled into a thin string between your palms when wet it's probably mostly clays. It should work well for spreading and growing things in.
Egon
   / What to do with dam (pond) silt #6
When my father had his trout pond clean of the silt,he had it spread in the low areas of his lawn etc..and the grass grow twice as fast..yikes.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
Sterling AT (A53473)
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
