What To Do With All of These Rocks?
   / What To Do With All of These Rocks? #1
Haneyrm
Water Valley, Tennessee
Howdy,
One of my fields is covered with softball sized rocks. I have no idea where they came from but they are destroying my bush hog. I have tried to corral them with my landscape rake with mediocre results. Is there a better way to deal with these rocks? The field is approximately 20 acres and has a pretty aggressive slope to it. I will not drive sideways across it on my tractor. I have read that a Harley Rake will do the trick. What is a Harley Rake? Sounds like a basic landscape rake with way too many chrome trinkets hanging off of it and is way overpriced! Probably vibrate you to death as well. Any help is greatly appreciated.
Mike
   / What To Do With All of These Rocks? #2
Well you could have the First Annual Water Valley Rock Pickin' & Outdoor Festival.. Get some hay bales for sittin', a porta-potti or two, and a concession stand.. Charge a small admission fee and as a suvenier let each person carry all the rocks they can in their arms to their car.. LOL
good luck. Im sure someone can give you a real answer soon..
Brian
   / What To Do With All of These Rocks? #3
Here's what I did...rebuilt an old chimney and built a short wall around the area...whenever it rains I get more rocks! I think they breed undergound on moonless nights! Photo is attached
   / What To Do With All of These Rocks? #4
I have a feeling this is the Harley Rake mentioned (leather jacket not required!):
Harley
I've also heard mention of a Rock Hound, but they're pricey and I've never used one myself:
RockHound Attachments
I usually just manually pick them up and put them in little piles that I can see, but I don't have nearly as much cleared land to deal with. Perhaps you can rent a skid steer with a rockhound for a weekend?
   / What To Do With All of These Rocks? #5
A few teenage boys and a trailer will take care of you field of rocks in a day.
   / What To Do With All of These Rocks? #6
There are rock rakes:
- Harley Rake
- Rock Hound
Rock Buckets:
- Silver Bullet
- Virnig
and rock pickers.
The rakes work well to make an area that does not have much semi-imbedded rock into a seed bed. I haven't seen them do a good job when you have a bunch of imbedded rock. They tend to just clear off the top down to maybe 1/2". The rock buckets work well but are slow. You can get under the surface a little and scoop them up. This is a slow process but it works. I've seen rock pickers advertized on different web sites. These appear to be more of an industrial product.
Here's what I do, very slowly.....
Till as deep as I can while clinching my teeth. Use a landscape rake to seperate the rock from the dirt. This only works on dry ground and seems to work alot better now that I have a top link where I can curl the rake toward the tractor some. I then move the rocks to a breeding pen (or at least an area where they don't bother me so much). I figure I can finish my 10 acres in about 80 years....
   / What To Do With All of These Rocks? #7
They also do not hibernate :eek:. They mate all winter long in NE :D!- Jay
   / What To Do With All of These Rocks? #8
That's my method. Several years ago, we cleaned up a rocky pasture by giving my son and some of his school buddies $2 a 5-gallon bucket full of rocks. For $350 I got the pasture cleaned up AND got enough rock to fill in a couple sink holes.
   / What To Do With All of These Rocks? #9
Mike!
I can't believe that you are so unappreciative of the great state of Tennessee's free gifts. They are (as previously mentioned) fireplaces, walls, benches, gate posts, etc. They come unassembled with no instructions (kinda like "batteries not included").
Seriously, a Harley does a pretty good job of getting the ones that will clobber your rotary cutter. Our co-op rents em since no one wants to buy one to use 4-5 days a year.
   / What To Do With All of These Rocks? #10
Haneyrm said:
Howdy,
Mike
I just bought a rock windrower. (A 9' harley rake type with 6" teeth.)
Since your rocks are smaller sized - how about renting a massive roller & pressing them back into the ground - easiest! This will leave the field smooth as well.
A Haybuster 106 is a combination windrower, ferris wheel picker - cleaner, and a dump wagon on the rear. $15K new but works. Pull it behind your tractor and dump the box when full. Leaves the dirt behind.
Rock buckets will pick up dirt with the rocks and if you have sod, it will pick up a lot of it.
The rock hound works until smaller rocks jam the rake tines and you need to stop & reverse clear it.
A rock picker bucket type is good for larger rocks that are not easily windrowed. Has the same problem as a rock bucket with dirt & sod. Rotating rake style picker is better but has rockhound jamming problems priced at $6K and up...
My rock tools range from a dozer to this little thing I just put in the barn - 28 HP and can easily can see the front pickup edge. The rock picker attachment is a modified manure bucket still under construction.
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
71066 (A49346)
71066 (A49346)
