What to do...What to do....
   / What to do...What to do.... #1
dmfahie
Limington, Maine
J.D. 2305
I have a few options for getting a Cub Cadet.
I posted about a 3165 & Snowblower for (500/600hrs)$4500, There is a 3168 @ a dealer for (500Hrs) $1900. with no snowblower, then I could find a user one. Or should I loo at the Home Depot 1054 (26 HP Kohler) with a blower for $3300. (With Blower, Softside cab & weights)
These are way too many decisions. Any Advice????
   / What to do...What to do.... #2
Personally I would stay away from any of the 1000, 1500 series cubs. Not that they are not well made or prone to braking down, its just that they are not made for much more than mowing a lawn. I own a 1018 and that's about all it will do. Don't let the high horse power confuse you either. I believe that the high horse power just equals higher rpm not necessarily higher power.
I firmly believe in a shaft drive not belt drive. I just bought an older 1882 with 18 hp (2 cylinders) and shaft drive and it will do things that the 18hp 1018 can only dream of.(belt drive)
I think that if you are snow blowing you would want something with some weight to it and a shaft drive for torque and a 1054 will not give you that.
Believe me from experience that what you think might work is probably too small and you should get a tractor a little bigger than you think.
Take my opinions with a grain of salt as I am not an expert but only can convey what I've recently researched and experienced.
Bottom line, get one of the 3000 series.
Papaglide, great advice, I agree. I am not educated within this field and want to confirm my assumptions.
Thank You.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
