what to do before slab is poured for shop
   / what to do before slab is poured for shop #1
bdog
Elite Member
Texas
John Deere 6130M
I am having a 50x50 shop being built. They have the forms set. I already put in the pipes for a future toilet and sink and ran a conduit for the lectrical coming in. Any thing else I should consider putting in before they pour the slab?
   / what to do before slab is poured for shop #2
How about a drain in the floor if you are ever going to hose it out or for anything that might leak..also a pvc pipe maybe 2" going to the outside from wherever you envision ever wanting to run wires or anything to the outside.
   / what to do before slab is poured for shop #3
Possibly a floor drain if you ever get the hankering for washing a vehicle inside. Sounds like you will have water in there so there is always the chance.
   / what to do before slab is poured for shop #4
They sell pvc floor drains, I'd add one in the center plus make sure the door areas slope outward to shed rain, snow...it's anoying to have to keep a squeege around to clear the floor b/4 working on the equipment you just brought in from the rain...
I worked at the corner gas station as a teen and the first snow fall, bringing in everyone who needed snow tires & chains mounted had us pushing the squeege across the whole shop every time.
   / what to do before slab is poured for shop #5
Are you planning to put a moisture barrier under the slab?
   / what to do before slab is poured for shop #6
Consider installing the tubing needed for a heated floor. I understand that the tubing is not too expensive. Down the road you could add a boiler.
   / what to do before slab is poured for shop #7
I agree, you need something to fight moisture. Plastic, gravel or both under the floor help a lot.
   / what to do before slab is poured for shop #8
If you can get a car in then I would consider at least two drains, and also a conduit for other wires like a phone and network cables that you would not want with your electricity. I have a newly built 28x32 shop/garage and I sometimes wish I had thought of that before.
   / what to do before slab is poured for shop #9
Hello
Don't forget to treat for termites.
Bill
   / what to do before slab is poured for shop #10
hmmm let's see.........my ex-wife? :D:D:D
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
BELSHE DT-235 (A53843)
