WHAT TO BUY? MF2625 OR A JD5103 FWD?
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #1
ron2nc
CLINTON,N.C.
MASSEY FERGUSON 2605 2WD AND A CASE FARMALL 70 MFWD WITH FEL
I NEED TO BUY A TRACTOR AND HAVE NARROWED IT DOWN TO THESE TWO. ANY HELP WOULD BE GREAT. IM GOING TO USE THE TRACTOR TO MOVE AROUND A 3 INCH REEL THAT HAS TO PULLED OUT 300 FEET.
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #2
I don't like the drive shaft for the MF 4WD. It runs down the side of the tractor. They say it's so they can keep the tractor lower. But I don't like the way it looks.
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #3
Need more information! A 3" reel of what, for what? Or am I just fishing with waaaayyyy to light gear!?!!?? ~Scotty
it is an irrigation reel to water crops
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #5
MF2625 seems to be a little bit bigger tractor based on specs. 5103 is a simple tractor that should prove to be very durable. 2625 will have more HP and capacity.
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #6
I would suggest using the seach thread function and research what actual owners say about their machines. I did that exact thing when looking at a particular tractor. I was looking at a 5103 until I started reading comments from actual owners. Some like it but others were not pleased with it.
Good Luck
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #7
I like red stuff, but buy where you think you'll get the best support. If you think the support is the same, buy whatever tractor is the best value. Not the cheapest, but the most bang for the buck. They are both pretty basic tractors that should give you a good service.
   / WHAT TO BUY? MF2625 OR A JD5103 FWD? #8
That is very durable. The have been building their work horse utility tractors like that for years. Go look at a 200, 300, 400, 500 series. I am sure you will be suprised at what you see.
Good luck.
i think i have decided on the mf2625 mfwd. i have a 2605 2 wheel drive and love it. i like the shuttle on the mf because of having a fel. the jd was the best deal though.
2019 FORD F-550(INOPERABLE (A52472)
2019 FORD...
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
2019 Nissan Sentra Passenger Car (A51694)
2019 Nissan Sentra...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
