What to build? 72ft of 6" wide flat bar
   / What to build? 72ft of 6" wide flat bar #1
myyaz33
Platinum Member
Nebraska
TYM T273
I was needing some steel to test out the new Hypertherm and got a great deal on some flat bar I could not pass up. I'd rather have gotten some sheet to play with but this is what I got.
40ft of 1/2"X6"
32ft of 3/8"X6"
Now what to build? Thought about a grapple, but what other types of things could this type of material be a good fit for?
   / What to build? 72ft of 6" wide flat bar #2
Rock bucket?
Hmm.. We don't have many rocks around here but that looks like a good candidate.
   / What to build? 72ft of 6" wide flat bar #4
Use the 1/2 inch for sides and tailgate of a grading scraper. Use the 3/8 to make the angles to mount cutting edges, and the 3 pt.
Bruce
   / What to build? 72ft of 6" wide flat bar #5
Yeah, I smell a nice grader from that stock.
Wish you were closer as I'd swap some different stock with you as I am always short of wide flat stock.
LOL, I have a buddy that loves old oil storage tanks. He cuts and converts to them to flat sheet metal stock to make trailers from.
   / What to build? 72ft of 6" wide flat bar #6
Ballast for your pick-up when the snow starts falling.
   / What to build? 72ft of 6" wide flat bar #7
Piloon,
How does your buddy flatten out the curved sides of the tanks?
   / What to build? 72ft of 6" wide flat bar #8
Well if you got it cheap, spending a few bucks on having that 3/8 plate bent into some angle, that would widen your choices of projects. I find that I use a lot of both of your thickness in a 2" wide "flat" for misc. bracing & gussets on a lot of projects. If your getting something bent, you may as well have some of it sheared into some various sizes also.:thumbsup: Oops, I guess that might be a job for your new Hypertherm!
I just picked up a new (updated) torch for my 15 y.o. Hypertherm yesterday!
Bruce
Already have a box blade but another good idea..
Pretty sure the guy I bought this from has some angle and channel at the same price, so I am not sure it would be worth the trouble of bending.
40' CONTAINER (A51248)
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
Miscellaneous electrical stands (A53117)
Miscellaneous...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
2018 Ram ProMaster City Cargo Van (A51692)
2018 Ram ProMaster...
