What to attach?
/ What to attach? #1
stevewilli
UK, south coast, on a cliff
I am considering buying a BX2350. I have about 3/4 of an acre of lawns which I would like to close cut plus about 1 1/2 acres of rough pasture and about another 5 of woodland in which the trees area fairly close and I want to keep down the undergrowth around and under the trees. Will a 48inch mulch deck with rear discharge be my best bet? Also, have a fair length of drive mostly beneath trees which I want to keep swept. Can I fit a front mounted rotating brush to the BX? Any advice much appreciated.
/ What to attach? #2
Hello Steve,
I recently purchased a JD X749 for my slopes and tight turn radius. I haven't yet mowed, but I have tried its climbing and stability performance. So far, I am quite impressed. I put it sideways (near the bottom of a slope), and it felt very stable even when pulling on it in an attempt to raise a wheel. This is in a same spot where a taller tractor feels very uncomfortable. The BX and JD cut/scuts are real work horses, but for just mowing the slopes, the X is great! It has all wheel drive (+ diff lock) and 4 wheel steer for a 6" uncut radius.
/ What to attach? #3
In my opinion, which doesn't really account for much, I would get a 54 or 60" finish mower for the lawn, which will make it look well kept and manicured. Then I would get maybe a 48" brush cutter for the pasture and tree area. I think using a finish type mower in the pasture and tree area would work for a while, but eventually that type of use would destroy it, and a rough cut mower will leave a little to be desired on the lawn. A 2350 will handle a 48" brush cutter and a 60" finish mower with no problems. Hope this helps.
Pat
/ What to attach?
Skidoo, I wish you hadn't mentioned the X749. I think its definitely more suitable for my property being both 4WD and 4 wheel steer. Only problem is that I don't think its available in the UK so would have to do a personal import.
Also Shantycoke. What's a 48in. brushcutter? Is that what I'd call a flail? Does it go on the rear pto?
/ What to attach? #5
I'm probably a contrarian, but unless I was going to cut brush forever, I would not buy a 48" brush hog for your BX. Yes, that's the size recommended. But if you have it mowed down once and then can keep after it regularly, I don't see any reason not to buy a 5 or 6 foot tow behind cutter. The 3PH might not be able to lift a 6ft 3PH mower, I don't know, but powerwise, I'm sure it can handle it in "reasonable mowing".
As a kid, I mowed with a ford tractor and 5ft mower in pastures. It took FOREVER!
Hope this helps.
ron
/ What to attach? #6
Hope this helps.
ron
I had a BX 2230 with a 60 inch finish mower. I cut about 4 acres of lawn regularly, and have a 2.5 acre field I mow a couple times a month in the warmer weather. I didn't have a brush hog with the 2230, so I used the finish mower to do it all, and that 2.5 acre field did a number on the mower deck and blades, and the lawn showed it. I ended up getting a brand new 5' International brush cutter for 750.00 when I got my new B7800 last year. The finish mower on the 7800 is for the lawn only. I figure by spending $750.00 on that brush cutter, it saved me from tearing up a couple thousand dollar finish mower. I also use the brush cutter for keeping logging roads clear.
The original poster shouldn't have too much trouble keeping a 1 1/2 acre pasture looking good with a 48" cutter, and his BX would have no trouble handling it.
Pat
Coleman Powermate Generator (A62613)
Coleman Powermate...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
John Deere 490E Excavator (A62679)
John Deere 490E...
Cedar Boards (A65640)
Landhero Electric Hoist (A66408)
Landhero Electric...
