What to add to hard soil?
   / What to add to hard soil? #1
jeff408
Randle WA
JD 4300
My moms back yard soil is very hard and for mothers day I would like to rototill it up and plant some grass. I'm wondering if there is something I can add in to her soil when I rototill so that it doesnt set up so hard. I'm not sure what kind of soil it is but its not clay. I'm wondering if something like sand or maybe pummis might work. I would sure appreciate any help.
Thanks, Jeff
   / What to add to hard soil? #2
Peat moss would probably be the best thing, but most anything organic could work
   / What to add to hard soil? #3
sand (and more text hear because the forums are to stupid to understand that just a reply of SAND is sufficient to answer the question)
   / What to add to hard soil? #4
sand [SIZE="1.5"](and more text hear because the forums are to stupid to understand that just a reply of SAND is sufficient to answer the question)[/size]
After the sand a good ripping with a sub soiler will do wonders and let the sand greatly increase the perk test readings.
   / What to add to hard soil? #5
I didn't understand that reply. :confused: Not that I need to, but ??
Seems the OP would want to first find out what kind of soil he has. If not clay, what is it that would get so hard?
If it is so hard, can it be rototilled, or will it have to be ripped up first? And if ripped up, will the rototiller knock the hard soil apart?
Seems organic material would be what the soil needs, but it sure acts like it is clay. If clay, I've worked a lot of sawdust into the soil with a rototiller, and added nitrogen to help break down the sawdust. The wood fiber helped make a very lush lawn and grass bed.
Organic material will help the worms go to work, and aerate the soil.
   / What to add to hard soil? #6
Naybe its that gumbo stuff like that have up by Dallas. When its wet its like glue, when dry like a rock.
   / What to add to hard soil? #7
Likely referring the the requirement that answers be longer than 4 characters. Try just posting "yes" sometime.
All good answers so far. Organic material, subsoiling is good, as is sand. All of the above, but just ripping alone without putting in the organix, (compost, peat, leaves, sawdust, ashes, etc to build bulk and fiber) won't last but a year or so and it will likely re-compact. Soil is more than dirt.
   / What to add to hard soil? #8
After adding [sand and organic mater] ?? you may want to plant a green manure crop and till it in before planting grass. Might give the ground a little more time to incorporate the new ingredients and loosen up. :D
   / What to add to hard soil? #9
Organic matter of any type, brown or green, preferably both..
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Military Rear Differential w/ Tires (A50121)
Military Rear...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
