What tire pressure R U running?
   / What tire pressure R U running? #1
NoTrespassing
East Central Illinois
Kubota 1999 L3710 HST FWA
I loaded my 17.5-24 R4s about 40% full today. I aired them up to about 18psi. I noticed the book calls for 20psi. Is this considered a max. pressure, and if so, what is considered a min. pressure? I've read recently about a guy running 9psi. I'm not sure what kind of tractor or what tires he had.
Kevin
   / What tire pressure R U running? #2
I asked the Titan tire technical service rep a similar question. I was told to run the R4s on my B21 at exactly the number specified in the manual. I'm not sure what size tractor you have. If you have a backhoe, it is imperative that the tires are correctly inflated because of the pressure exerted on them when digging. If they are underinflated, you can develop a bubble on the sidewalls of the tires.
By the way, the Titan tire customer service was excellent. And, their web site was helpful too.
   / What tire pressure R U running? #3
I used to run 8 lbs on my ag's until one day, when I was doing some fel work in some muck, both rear tires got a little deep and spun on the rim. Not a pretty sight. Brought the pressure up to 18 and never had to worry again. (keeping my fingers crossed /forums/images/graemlins/grin.gif)
   / What tire pressure R U running? #4
I can tell you from experience that R4s of that size, filled, at 20 degrees F, with 1000# on the 3pt, really ought to have at least 12 psi.
Mine had 12 psi at about 40 degrees F but went down to less than 10 psi when the temp. dropped. That's when one of them spun as soon as I picked up the load on the 3 pt. I now run between 14 and 18 psi in both R1s and R4s.
2013 FELLING  SKINNYNECK TA LOWBOY (A53843)
2013 FELLING...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
Eaz-Lift Elite Weight Distribution Hitch Kit (A53117)
Eaz-Lift Elite...
