What tiller is this?
   / What tiller is this? #1
chck4342
woodville,Alabama
Yanmar FX18D
I just picked this up for next to nothing for my FX18D and am not quite sure what kind it is. The markings are all gone but it seems that the serial plate had japanese writing on it with the numbers RS1200 and 22197 which I guess is the serial number. Could this be a Yanmar RS1200 tiller?
Several tines are missing. They are marked 2545R and 2545L, I assume for right and left. I did a search here and maybe Danny Parker with Parker Euipt. here in Alabama might be a source? Anyone know where they can be had? I just need two. The shank of the tine measures about 9/16 x 3/8 thick and is held in with about a 10 mm bolt. Any help would be appreciated!
   / What tiller is this? #2
Since you are from around here. Check with danny...I have his ph # if you need it. I can pm you with it
That would be great...thanks...Any idea what this is?
   / What tiller is this? #4
It lookes alot like my Yanmar tiller, it has the same teeth as mine.
   / What tiller is this? #5
check you'er pm
So I have found upon disassembly of my "new" RS1200 tiller, the spline shaft bearing is bad. Its the one opposite of the drive chain. Does anyone have a parts diagram of this or give me an explanation of how to disassemble and reasemble? Any idea of a source or part number for the bearing? Thanks
   / What tiller is this? #7
Check out Fredricks' Yanmar Tiller Parts Catalog. it'sn the left column of this catalogs list on their site.
And several other Yanmar specialists sell out of that catalog too, perhaps one local to you.
added-
I just noticed 'drive chain' in your post. I thought the Yanmar tillers were all gear drive. With the orange paint, could that be a Kubota tiller or something? It doesn't look like it would be an exact little brother to my RS1400.
Yes it definately is a chain drive, and the id plate is stamped RS1200 which leads me to beleive its a Yanmar. Maybe some one here has a 1200 that they could verify that there's is a chain drive.
   / What tiller is this? #9
   / What tiller is this? #10
This was posted on CL.ATL. 4ft Yanmar Tiller.Might try to reply and ask for the Specs.The drive side cover does look different.
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
