what throttle setting
   / what throttle setting #1
ernemats
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
I was just wondering what throttle setting most people use when running their gas engine power tracs. I usually run mine (422) at half to three quarter except when mowing thick high grass or using the tiller , then it is three quarter to full. When using the light material bucket it is usually less than half.
I would like to hear from others and also Jack at Robin
   / what throttle setting #2
I think most would say they run at full throttle all the time. In my case I usually run half throttle for most work with the exception of mowing and trencher (full). Soil condition plays a big part also.
PJ
   / what throttle setting #3
I'm pretty much a half throttle ± man /forums/images/graemlins/smile.gif unless I need the extra speed/torque that more throttle would give me. But with a postage stamp lot like mine (1/10 th acre), more speed would put me in the lake before I could say 'spit' /forums/images/graemlins/wink.gif
   / what throttle setting #4
You know me... FULL THROTTLE!!! /forums/images/graemlins/tongue.gif
But seriously, I warm it up at about 1/3 throttle in really cold weather, then use pretty high throttle settings, especially when doing FEL and mowing chores. I like to have all the power available all the time. Plus, I like the noise! /forums/images/graemlins/wink.gif
   / what throttle setting #5
Starting: 1/4
Running: Full
Regards,
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
   / what throttle setting #6
Well, for me, I run at the throttle setting that will perform the work I need to have done. Most of the time this is 1/2-3/4 throttle. Of course when I mow, I run at full throttle.
I know the MFG likes full throttle, but that's how I do it.
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / what throttle setting #7
I run my 422 at full throtle to mow, 1/2 for FEL work, and 1/4 to !/2 for the mini hoe, that way if I get a hold of something hard I won't break anything.
   / what throttle setting #8
1/4 to start...then adjust to use(as already stated)....
Jack:
Do you mean we should run it at full throttle even when doing jobs that require little speed or power? If so, is it not good for the engine to run at less than full throttle and why?
   / what throttle setting #10
</font><font color="blue" class="small">( Do you mean we should run it at full throttle even when doing jobs that require little speed or power? )</font>
Ernest, I've no experience at all with Robin engines, but being an old timer, I'm frequently a little surprised by "new" changes in engines. For one thing, I've always believed in slowing an engine to an idle before killing it. Well, my daughter has a Lawnboy mower with a Tecumseh engine that has no throttle; it runs the same speed all the time, right up until you kill it. And I recently bought a Toro ZTR withe a 14hp, single cylinder Briggs engine that does have a throttle. You push the throttle to the wide open position, then a detent, and you push it on past the detent to the "choke" position to start it, then back to the wide open position for operation. Now the thing I don't understand is the fact that you can pull the throttle back to a slower or idle position, but if you turn it off at idle, you get a loud "backfire". The manual says to kill it at full throttle and then it dies peacefully. /forums/images/graemlins/wink.gif So I'm not sure why they even have the throttle that will let it run slower.
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
FAKE (A52472)
FAKE (A52472)
