What the heck is making these holes?
   / What the heck is making these holes? #392
Ha! Got the culprit, maybe? Don't even know what this is, but could it chew such nice even holes?
Chipmunks. They seem to have spread out their habitat in Ontario the last few years. They are quite destructive for their size.
   / What the heck is making these holes? #393
Yes chipmunks! Also sometimes called ground squirrels by old timers. I am getting to be one of those I guess. Your holes look like carpenter bees to me. Usually the will chew into boards from the bottom then possibly turn in there bore to run the length of a board. They build nest and then you get a whole new batch.
They can affect the structural integrity of wood. You should be able to spray for them, but it is a continual process.
   / What the heck is making these holes? #394
I've never seen a rodent ( mouse, rat, squirrel, chipmunk, etc.) chew a hole with smooth sides, there will always be teeth marks. Carpenter bees cut holes that are 3/8" diameter, the OP said these were about 1". Not convinced that these are the answers.
   / What the heck is making these holes? #397
Wood borers
Yup, definitely!
My lingering question is, what kind? Given the 1" size and apparent pattern, here's my latest
guess. :)
   / What the heck is making these holes? #399
But these holes are 1" diameter with smooth sides, any bug will make the sides a bit rough. And since these holes are evenly spaced and all in a row, I'm sticking to this was an old beam that had a pin in it, boards were sawn from this beam, and after all this time, they finally shrunk and fell out or rotted away.
   / What the heck is making these holes? #400
Very well could be. If not, they are probably powder post beetle larvae.
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2016 John Deere Gator (A55973)
2016 John Deere...
2022 Wacker Neuson LTV6 Towable Light Tower (A55851)
2022 Wacker Neuson...
UNUSED RAYTREE RMA42 HYD AUGER SET (A57193)
UNUSED RAYTREE...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
2024 BOBCAT E60 R2 SERIES EXCAVATOR (A52707)
2024 BOBCAT E60 R2...
