What the heck is making these holes?
   / What the heck is making these holes? #272
You guys will never guess! Bruhahahaha!
Not without a picture and more information/history of the site.
Otherwise we're making educated guesses from your limited information and our experiences or pulling stuff out of our arse.
So, either hints/information or put up.
   / What the heck is making these holes? #273
I'm with check at this point... the collective intelligence of this forum should have solved it! But on the other hand, we haven't solved the pallets in the fields so I yield the floor.
   / What the heck is making these holes? #274
Nope... all check has said is that it's a 3'x3' slab of concrete with 4 bolts sticking up. No description of where the bolts are or orientated... corners? Ring(ish) in the middle? We need more to go on before I accept a "Bruhahahaha!" :mad:
Heck, old sparc gave us a bit more information before he (mysteriously) disappeared from the Pallets in Fields thread.
OK, I will go over today and take ONE picture, and I will tell you that the property is the oldest on Kawagama Lake (about 100 years old, but not all the buildings are that old), and was at one point a hunting and fishing camp.
   / What the heck is making these holes? #276
It's for a tower that held a navigational beacon for aeroplanes.
   / What the heck is making these holes? #277
Now, I'm really perplexed. How can one plot of ground be older than the ones all around it?
   / What the heck is making these holes? #279
3x3 base sounds too small for a windmill. I'd guess antenna base or light beacon since it was on a lake.
Or maybe some sort of fruit press. Something related to plant or animal processing, perhaps.
   / What the heck is making these holes? #280
Exactly! An important clue! It's because of the time warp that's at the root of this mystery.
In fact, it may even hold the answer to the pallets in the field.
Utility Tilt Trailer (A55787)
Utility Tilt...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2020 Ford F-250 (A55973)
2020 Ford F-250...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
1974 Ford F600 Grain Truck (A55315)
1974 Ford F600...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
