What the heck is coming out of my tires?
   / What the heck is coming out of my tires? #1
sparkle
I noticed recently a thick sticky brown/black liquid on my tires. I first thought that it was water but a closer look reveilled a sticky stuff. It is al over the tread of the 4 tires but doesn't seem to eat in it, at least for now. It slowly leaks down on the sides of the tires. I drive the tractor in the snow and it appears shortly after I put it in my heated garage. I never seen that before, just recently. No oils or other stuff that came near this tires. Outside everything is snow covered. This tires are R4's from Firestone. Any ideas or similar experiences?
   / What the heck is coming out of my tires? #2
On the threads???
From what you describe it sounds like bead lube. Usually dabbed on the rim around the bead to help the tire slide on. Never seen enough of it put on to actually leak out though and when you do see it, it's usally around the rim where the tire meets the rim. You got pictures of this stuff you can post?
Here are some pics!
second try!
   / What the heck is coming out of my tires? #5
Try not posting them as .zip files...tough to view directly and not many willing to download to their computer, unzip, open, THEN look at your tires.
If they're too big, you can lower the resolution through most any photo editing program.
   / What the heck is coming out of my tires? #6
I tried downloading and that did not work either. I went to Google and typed in resize pictures. There are a number of websites that do it for free.
   / What the heck is coming out of my tires? #7
You have to download them to your drive, then right click the file and choose unzip here for the fastest way to do it. A PITA that's for sure. After looking at them I don't have a clue what that stuff is!!! It doesn't look like it's coming from the inside of the tire but spraying out from somewhere???
   / What the heck is coming out of my tires? #8
Jpg's of the clear ones... Beats me what it is...
Hi all,
Sorry for the trouble with the pictires. i was in a hurry and did not double check them. I just came home and saw the problems. Thanks for rectifying this!
As a note please ignore the date which states 2003, this pictures are recent (daughter played with the camera) and i just cleaned some snow here and it seems to come back. Now I'm worried that this will shorten or destroye the tires. I phoned and emailed the pictures to the Dealer who is momentarily attending a Kubota meeting. He told me that this is something Kubota will defer to Firestone, but he will try to access the pictures and show them.I showed this already to some people and nobody sofar has seen this before. Are most of the factory tires Firestone?
   / What the heck is coming out of my tires? #10
Did the dealer load the tire with Ballest star?
24FT Enclosed Trailer (A53424)
24FT Enclosed...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
