Grapple What stuff do i need, other than the actual grapple?
   / What stuff do i need, other than the actual grapple? #1
mrwizard64
Glenmooren Pennsylvania
None
Hey guys... I'm trying to throw a root grapple on my kubota L3940 (which has skid steer quick release). Other than the actual grapple itself, what the heck do i need to buy to make this work?)
Im assuming some hydraulic splitters and tubes, but i have no idea what else.
Anyone feel like helping make a list?
   / What stuff do i need, other than the actual grapple? #2
If your tractor has rear remotes you just need a couple hoses to reach the front and the proper fittings. If you don't have rear remotes one of the hydraulics experts here will answer what you need.
I don't use my rear remotes so that was the cheapest way for me to get hydraulic line to the loader.
   / What stuff do i need, other than the actual grapple? #3
You will need what is called"third function" ,either the Kubota factory set-up or an after-market from various sources.
   / What stuff do i need, other than the actual grapple? #4
WR Long makes complete kits with what you need. You can call them directly or I think Everything Attachments carries them based on your model
Sent from my iPad using TractorByNet
   / What stuff do i need, other than the actual grapple? #5
If you go the diverter route, you'll need hoses made or modified (what I did) to direct the valve's output into the diverter, then hoses to run from the diverter to the front of the boom arms. You'll need some kind of quick connects for the tractor side, and might want different ones than the grapple comes with (maybe skidsteer flat face? I did that since I have a SSQA mount on my loader). You'll need some form of switch to activate the diverter, and then a bit of wire to connect it all.
Making your own "kit" isn't all that hard. I found it a mostly enjoyable process.
   / What stuff do i need, other than the actual grapple? #6
I got a W.R. Long complete kit from Everything Attachments. Simple instructions and a real easy job to install.
I just got the whole kit from everything attachments... That made it very easy!
   / What stuff do i need, other than the actual grapple? #10
No I don't! I bought that too! Dual lid, 60 inches.
(You know what would be cool though... Other free stuff!!!!)
:-D
Sweet. Thank you for all of the business!
You will LOVE that combo.
You should've received $50 off for buying both together. If not, let me know and I can take care of it.
Travis
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2012 Cadillac SRX SUV (A55758)
2012 Cadillac SRX...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2014 Ford F-150...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
