what size
/ what size #1
grasskutter
maypearl tx
mahindra 3505 DI
i have 3505 DI looking to get a bigger shredder i have a 6ft now. thinking about 7ft 3pt or a 8ft pull type. i do alot of mowing and its time for a new one.
/ what size
/ what size #3
Grasscutter,
I have a 3510 with a 7' finish mower on the back. Be aware that this size mower usually is a larger category hitch (wider, larger pins).
I went to my local machine shop friend and had him turn down a pin for me out of larger stock.
It is large enough for the mower hitch, small enough and extending inward about 6 inches with a collar. This handles both the diameter and width issue.
As for HP to turn, not too bad. Can't mow at top speed, but easily turns mower unless hitting 3-4' unmowed areas.
Oh, and if you trailer it with the mower up like I do (to fit on trailer), be sure to secure the mower well, as it will be heavy and tend to swing and sway the trailer.
Hope this helps.
-DiskDoctr
/ what size #4
Grasscutter,
Hope this helps.
-DiskDoctr
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
4004SFL (A59228)
4004SFL (A59228)
Demco Lowboy Trailer (A65563)
Demco Lowboy...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
