what size
   / what size #1
grasskutter
maypearl tx
mahindra 3505 DI
i have 3505 DI looking to get a bigger shredder i have a 6ft now. thinking about 7ft 3pt or a 8ft pull type. i do alot of mowing and its time for a new one.
   / what size
   / what size #3
Grasscutter,
I have a 3510 with a 7' finish mower on the back. Be aware that this size mower usually is a larger category hitch (wider, larger pins).
I went to my local machine shop friend and had him turn down a pin for me out of larger stock.
It is large enough for the mower hitch, small enough and extending inward about 6 inches with a collar. This handles both the diameter and width issue.
As for HP to turn, not too bad. Can't mow at top speed, but easily turns mower unless hitting 3-4' unmowed areas.
Oh, and if you trailer it with the mower up like I do (to fit on trailer), be sure to secure the mower well, as it will be heavy and tend to swing and sway the trailer.
Hope this helps.
-DiskDoctr
   / what size #4
Grasscutter,
Hope this helps.
-DiskDoctr
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
2004 DYNAPAC CA152PD PADFOOT ROLLER (A51242)
2004 DYNAPAC...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
