What Size Trailer
/ What Size Trailer #51
1*Sure it's simple enough to take a look at the specs on the door plate but what's not so simple is finding a used 1/2 3/4 and 1 ton pickup all at the same time so you can take a look at the 3 door plates to compare the specs between the 3 trucks.
That's no problem going new but used is a whole nother ball game.
LB, with used trucks, you can really only tell by the door sticker. One F-250 will not have the same GVWR, GCWR. and empty weight as another. There are too many options which were available at the time of manufacture that change the ratings. The only way you know for sure is the sticker on the door pillar.
In your situation, I would first determine the weignt of the load you will be carrying, your BX-23 being the heaviest of your tractors. Then take a look at trailers, and determine which one(s) you think will do the job for you. Find out from the dealer or manufacturer the weight of the trailer and the tongue weight. Add the weight of the load, the weight of the trailer, your weight, any tools you will be carrying, and the approximate weight of the fuel, oil, hitch, etc. This will tell you what towing capacity you need.
Then start looking for your truck. There must be sufficient load carrying capacity (difference between the weight of the truck and the GVWR) for 10% to 20% of the loaded trailer plus everything to be carried in the truck. The total weight of everything must not be over the GCRW. And it's best not to approach the rated capacities - they are maximums, and the truck and trailer will last longer if you are not always at the max. If either number is over the max, that is not your truck, simple as that.
Good luck shopping, and have fun looking.
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
John Deere 6195R (A60462)
John Deere 6195R...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
Snap-On Southern Thunder Edition 24-drawer tool box (A61307)
Snap-On Southern...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
