Tractor Sizing What size tractor?
   / What size tractor? #11
I'd say a Kioti CK20 would fit your needs quite nicely. It has the weight and power for snow removal,but not too heavy for the lawn.
   / What size tractor? #12
coasterez said:
You can do what you describe with a large garden tractor, like bota GTs or Deere 5xx/7xx or Simplicity. These are nimble machines that make great mowers and they perform well on snow removal too. It really depends on your exact needs, though. If you will need to do other chores you might want something a little bigger, like the quite versatile SCUTs, such as bota BX's or 2xxxx deeres. After that, you are into bigger and heavier CUT sizes. Now you have many many choices in this size with most bettered suited for one chore vs. another. Besides JD and Kubota, there are many options: NH, Mahindra, Agco/MF, Kioti, TYM, Montana, and more. I would think that 30 hp or thereabouts would be the maximum you would ever need. Understand your needs. Test as many as you can and filter down to those that best fit your needs. Then one or another will speak to you.
Word of caution: don't buy too small and regret it later. Just remember, bigger machines cost more and take bigger implements, take more storage space, are harder to maneuver in tight spaces, and may require a BIG trailer and truck to haul.
I agree with coasterez. What you are describing can be done with any garden tractor which would save you a lot of $. If you want 4wd for the plowing, a subcut would be the next logical step. As others have said, I would consider getting a blower if you get a lot of snow during the year. I would only go larger if you are considering doing some serious chores with the tractor.
2016 KENWORTH T680 SLEEPER (A57880)
2016 KENWORTH T680...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A55853)
1990 21ft Center...
2017 Kubota M7-151 Premium MFWD Tractor (A55315)
2017 Kubota M7-151...
2020 ASPT 16ft. T/A Flatbed Utility Trailer (A55853)
2020 ASPT 16ft...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
