What size tiller?
   / What size tiller? #1
mbw
Guys, I've been a long time lurker on this page, came here to decide on what compact tractor to buy. I ended up getting a Mahindra 2615 gear drive. Got to say I love it so far and has done everything I've asked it to do. I'm wanting to do some foot plot work and a big garden. I have decided on buying a King Kutter II rototiller. I am just curious if anyone out there is using a 5 footer with this particular tractor. I don't want to buy that one and then not be able to operate it. Should I go with the 4 footer instead, I would like to be able to cover the tracks of the tractor, it is 55" wide. Thanks for any input. Mike
   / What size tiller? #2
It should work fine, I have a 32 hp deere and use a 55" rototiller. Just go slow and your tractor will handle it.
   / What size tiller?
tiller size?
I have a 2615 gear drive and am curious if anyone is using a 5 foot king kutter ii tiller with this tractor. I posted on the attatchment section but haven't had to many responses. Please let me know if you are using this set up, I would like to purchase in the next week if the 5 footer is not to big for this tractor. Thanks for any help.
   / What size tiller? #4
Re: tiller size?
The 5' King Kutter tiller will not be any problem for the 2615 tractor to handle. I have had some customers use 5 1/2' tillers on the 2615 and have had no lack of power or lift capacity.
   / What size tiller? #5
mbw:
Welcome to TBN :D! Your 23 PTO HP should handle a 60" tiller. I have no problems with my 58" tilller and I am running around the same PTO HP. Jay
   / What size tiller?
Re: tiller size?
Thanks Galen, That is what I wanted to hear, someone who knows it will work. I'm off to TSC.. Mike
   / What size tiller? #7
I posted Pics.in Yanmar of a 24hp. 20hp. at the pto. with a 5ft. and IMO. it does a real good job.
   / What size tiller? #8
I have a buddy that has a Kubota B7610 (24 Engine HP and 18 PTO HP) and he runs a King Kutter II 6 FOOT (72 inch) tiller behind his tractor and it handles it very well. I have a 50 inch behind mine and mine doesn't even know its back there. I think you'll be just fine with the King Kutter II 5 FOOT (60 inch) :p
Troy
   / What size tiller? #9
mbw-
Since you have a gear drive an important consideration is to determine if your ground speed is slow enough in 1st gear at 540 PTO engine RPM to handle a 5 ft cut. Your soil type will weigh heavily in answering this question.
Jim
   / What size tiller? #10
Re: tiller size?
I own a 2615 w/HST and borrowed a neighbors 60" KK tiller. Worked just fine, then I went shopping, was ready to pull the trigger on a new one and found a Woods dealer with a 'demonstrator' in 60" and it works fine.
It's not a Howard, but...
CATERPILLAR V50B STRAIGHT MAST FORKLIFT (A51242)
CATERPILLAR V50B...
2011 CATERPILLAR 303.5 D CR EXCAVATOR (A51242)
2011 CATERPILLAR...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Shopbuilt Snow Plow (A50515)
Shopbuilt Snow...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
