Tiller What size tiller for 2 different tractors?
   / What size tiller for 2 different tractors? #1
Bob_Skurka
Super Member
I am looking for a tiller to use on a Kubota B2910 and a NH TC24D.
I would like the biggest tiller I can use on the TC24D that will still cover the tracks of the B2910 if that is possible.
How big of a tiller can I use on the TC24D? Is 54" a good fit? Can I go slightly larger? The TC24D has a 48" track, the B2910 is about a 54". The TC24D is 19hp at the PTO.
I like to be able to swap implements between tractors so I often have to compramise on sizes, but it gives me the flexibility to use either machine whenever I need/want to.
   / What size tiller for 2 different tractors? #2
You should be able to handle a 58" tiller. The only time you will be close to the max HP needed fro the TC24D would be when you are tilling heavy sod and trying to till at maximum depth. A Gear drive tiller is more efficient in the transfer of power to the tines than a chain drive tiller.
Why is gear drive more efficient at transferring power?
Which brands offer gear drive?
   / What size tiller for 2 different tractors? #4
Stronger Gears (no chain stretch), Less moving parts in a Gear Drive tiller, Less Friction in a gear transmission.
Most Tiller MFG's make gear drive tillers in their premium models.
   / What size tiller for 2 different tractors? #5
Mark, I certainly wouldn't disagree with you on the gear vs. chain drive on a purely gut feeling; just seems that the gear drive should be stronger. However, I ran a Bush Hog RTS40, chain drive, for 7 years; don't know many folks who would use a tiller as much as I did, and used it pretty roughly. The manual recommended changing the grease in the chain case after 100 hours; I waited until I'd run it a couple of years, and did that, although it didn't appear to have been needed. Then I ran it nearly 5 more years, and pulled the cover to check it and decided it didn't need anything done to it. Of course the tines were about 50% worn down. And a cousin has been running a Bush Hog RTS62 on his New Holland TC29D for a few years; heavily wooded property so lots of roots. One little area had been cleared with a dozer with rippers on the back and he caught a root that was big enough it came up, hung and bent the heck out of that rear hinged flap, but no other damage; no maintenance.
So, even though from a purely emotional feeling, I like the gear drive, that wouldn't be a factor at all for me in selecting a tiller.
   / What size tiller for 2 different tractors? #6
Bird,
I was only talking about the efficiency of a gear transmission over a chain transmission. The chain transmission is just a way for a MFG to cut some costs. The average customer in the USA using a tiller does so 4 hours a year. The chain drive can handle even 200+ hours a year but Bob Skurka wanted to know how he could maximize the use of his TC24D's HP.
   / What size tiller for 2 different tractors? #7
</font><font color="blue" class="small">( The average customer in the USA using a tiller does so 4 hours a year. )</font>
Four hours a year? /forums/images/graemlins/blush.gif Be hard to justify the cost wouldn't it? /forums/images/graemlins/laugh.gif
   / What size tiller for 2 different tractors? #8
If given the choice, you would like to have the premium transmission at the same or lower price wouldn't you?
   / What size tiller for 2 different tractors? #9
I was talking about justifying the cost of any tractor powered tiller for 4 hours a year, but yes, given the choice for the same or better price, I'd take the premium model. But if all I planned to till was 4 hours a year, I'd have kept my little walk behind tiller.
PALLET OF (2) COMPRESSORS (A55745)
PALLET OF (2)...
BELSHE DT-235 (A55745)
Utility Trailer (A52377)
Utility Trailer...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2021 CASE IH Steiger 540 AFS Connect QuadTrac Tractor (A53485)
2021 CASE IH...
Deere 331G (A53317)
Deere 331G (A53317)
