What size snow plow?
   / What size snow plow? #1
Jaybr
Cumberland, VA
Yanmar YT359
I recently purchased a new place and have a gravel driveway approximately 1/3 mile long. It's not flat but the hills are not too steep either. I used to plow snow at the old place with a rear blade on a Kioti CK35, this driveway is longer and I now have a Yanmar YT3589 cab. I don't expect a ton of snow, but 8-10" snow a couple times a year is not uncommon. I'm looking at Landpride STB1584 and STB1596 plows with hydraulics, a local dealer has both in stock. The 96" is a leftover 2023 model so its discounted making the price difference negligible.
Which size would you recommend for this 59hp, 4500lb (+loaded tires) tractor?
I'm not interested in a snow blower or snow pusher, I want to run down the driveway and push most of the snow to the side. Given the driveway is gravel, leaving an inch or two on top is not a big deal to me.
   / What size snow plow? #2
Would the 84” cover the width of your tractor when fully angled? I prefer the blade be at least 6” past wheels when angled so not driving on the snow that rolls back.
   / What size snow plow? #3
I have a similar tractor size and my plow is 90'', it is as big as I would want, bigger then that I would need snow chain on all tires because it just push the tractor to the side when the blade is angle.
   / What size snow plow? #4
i would get the 8 footer, any reason why you wouldn't just want to get a rear blade which could also help with your driveway/ditch maintenance?
I have a land plane that I'll use for driveway maintenance, don't really have ditches. I prefer to push mainly because I don't like turning around to watch what the blade is doing.
I also have a 6' rear blade, box blade, rake, and rotary cutter but they where all purchased years ago for the Kioti and a little small for the new tractor. I can't see using the Kioti with the rear blade when I have a cab now. :cool:
   / What size snow plow? #6
I run a 7' blade on my similar weight 40 HP tractor on a variety of paved driveways and no chains.
You didn't ask, but I will say that a rear blade may work better on gravel, particularly if your area doesn't support a frozen base of snow. Spinning a rear blade 180 degrees and back blading works very well on unfrozen gravel drives.
   / What size snow plow? #7
The width you need is a foot beyond the edge of the driveway when the plow is angled at max (45deg?) and certainly much beyond the width of your wheels. This is in case you get multiple snow storms and you now need to push the berm further away from the edge. The key to snow maintenance on gravel is to have the gravel surface groomed, packed, and plow ready BEFORE the snow storms hit. Then your plow skids won't ride up & down in potholes and ridges, digging up the gravel. When the snow first hits, drive on it with a vehicle and make some frozen tracks that the plow skids ride on instead of digging in.
  • Good Post
Reactions: JJT
   / What size snow plow? #8
I have a 10 foot repurposed county plow with power angle and I run front chains only on my 90 horse Kubota.
   / What size snow plow? #9
Yanmar YT359 width = 70.6 inches
Cosine of a 30 degree angle =0.866
8' blade x 0.866 = 6.928' which equals approx 83" of coverage width @ 30° angle.
83" - 70.6" = aprrox. 12"--- for 6" of the blade on each side of the tractor width.
   / What size snow plow? #10
I have a gravel driveway approximately 1/3 mile long. It's not flat but the hills are not too steep either. I now have a Yanmar YT3589 cab. I don't expect a ton of snow, but 8-10" snow a couple times a year is not uncommon. I'm looking at Landpride STB1584 and STB1596 plows with hydraulics.
Couple comments from someone who used to plow snow in CT using an 8' plow ( 800 Lb ) on Ford F350 4x4 Super Duty ( 6000 Lb).
Plow width, when angled, and tractor width are important since you don't want to be running tractor wheels on one side in unplowed snow BUT the wider the plow the more likely the tractor front end will slide sideways when plowing heavy snow. I'm thinking VA gets a fair amount of heavy wet snow and a 4500 pound tractor isn't really that heavy when potentially pushing several tons of wet snow.
My two cents worth. Get the 84" plow and make two passes both going down hill on driveway since plowing uphill requires much more front end weight and traction. Make two passes pushing snow off to opposite sides of the driveway. Unless the plow is severely angled or your plow has wings some snow will always flow off the edge that is pointed forward. Making a second pass cleans up this material. Make sure you get shoes to keep the blade edge from digging into the gravel surface.
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
