What size should I get?
   / What size should I get? #1
Willman
Southeast PA.
Mahindra 4110
Looking to get prices on 3 pt. rough cut rotary cutters for my 4110. I was thinking about a 6 ft. cut mainly because my dealer suggested no bigger than that.
BUT, do you think the 4110 will operate a 7 ft. without any problems?
I now pull a 5 ft. trailer type cutter with my Allis-Chalmers CA (26 hp) without any problem.
My thinking is that the 4110 should have the power for 7 ft.
Any thoughts???
   / What size should I get? #2
My 4110 will run a 7' mower without any problems.
Ernie
www.ernies.net
   / What size should I get? #3
Well, it all depends upon what you are cutting and when. I have posted alot about rotary cutters. I have a 6' and a 10' cutter. My recollection is that some think the 7' is the hardest percentage wise to operate considering the blades involved.
Also, depends upon how wet the cutting material is, how high it is, and how low you cut it, and how fast you want to go. I can cut real high stuff that is wet pretty fast if I move the cutting height up. If you want a nice low cut, sure you can cut it, but your going to have to cut in a low gear.
Also, be sure and grease your rear wheel every time you cut. That shaft and wheel are literally the pivot point for the whole cutter.
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
