howardx said:
My soil is pretty sandy, so i was hoping to use a standard 9" auger, instead of the compact tractor 6" version. I'll be setting some 4x4 posts for a deck.I was thinking the 6" version might be a little small for those post.What do you guys think?
The question in your title is about PHD size. The question in your text is about auger size. The PHD is analogous to a drill and the auger is analogous to a drill bit. Both come in different sizes, so it is not clear to me whether you are asking about the PHD or the auger. There are some PHDs whose U-bar is barely able to fit the 3ph arm width of a BX. As to the auger, the length is more of a concern than the width; a
BX24 will lift a bit higher than other BX models, but 42" length is about as long as you should go. You might make 48" on the
BX24, but with a clearance of as little as 2".
In terms of what width to use, the auger tip is far more important than the auger width. This is due to the differing types of material you might dig in. My Greene model will dig not dig in my clay when dry, but will when moist. When it hits the durapan, it just spins around, however, due to the blunt tip. I have 6" x 42" and 14" x 42" augers. Both dig about the same and have a 6" clearance at full 3ph lift height.
Land pride makes the PD10 specifically for subcompact sized tractors:
Land Pride PD10 Post Hole Diggers
The best augers to go with this are made by Pengo. Pengo makes a variety of auger tips that can be interchanged, some for soil, some for fracturable rock, some for non-fracturable rock:
Pengo
The Land Pride PHDs are available with downpressure kits to place the weight of the tractor on the auger tip.
Lately, there have been reports of new PHD units that attach at the place the backhoe bucket normally fits. This allows the use of the existing hydraulics in the backhoe to create downpressure without purchasing new hydraulic modifications. TBN member Ultrarunner has looked at some of these units at Green Valley Tractor (a Kubota dealer) in Suisun/Fairfield, CA.
These subjects have been discussed at great length in old threads. I would recommend that you do some searches in the archives here and gather more information before making a decision.
Good luck in your research, and have fun hunting for the right equipment.
