Rotary Cutter What size mower to get
   / What size mower to get #1
JohnsIH424
Louisiana
IH 424
Appreciate everyones help so far. Read threads about this but just want to be sure. My IH 424 is rated 36 pto hp and have a 6' jd rotary mower that is on its last leg. Looking at downsizing to 5' Bushhog sq160. Feel I can get what I need done and keep it in 3rd or 4th gear while doing so. Just some hunting trails and a few open fields. the terrain is flat on most of it with a few dips in one field. should I go 5' or stick with 6'? Tractor is old and worn too. (like me):) Also, thinking bout going with shear bolt instead of slip clutch. Appreciate any advice.
John
   / What size mower to get #2
Since you mentioned the IH is getting worn too I would be thinking ahead a little as to what I would be replacing my tractor with if it dies. If your thinking of downsizing the tractor at that point then consider the 5'. If your gonna replace with something in the same or larger horsepower stay with a 6'.
   / What size mower to get #3
I use a five foot on a 27 HP Kubota but would not want to do heavy cutting with it. Then I will cut grass that is 2 feet high fine.
Also think about the width of the tractor and mower. You need mower to cut the full width of the rear tires or the trail keeps getting narrower and narrower.
Great advice! I didnt think about the trails getting narrower. I would have to drive in the trees to keep it the same with the 5' foot! And, yes, when it comes time to replace the tractor, I would want the same size, at the least.
Thanks guys!
Oh....and I guess I will go with a shear bolt since I would be putting up after mowing a month at a time and don't want to have to fool with the clutch each time I want to mow.
Just wanted to thank ya'll for your help. I ended up getting the Squealer sq172 with a shear bolt. Got it hooked up and the tractor did great:thumbsup:! The grass was high and thick so had to stay in 1 and 2 to keep pto on speed but did raise the back and cut a little higher the first pass. Gotta say...big improvement over that old JD mower!! Thanks again!!
   / What size mower to get #7
that's great.
You made a comment on keeping the pto on speed and it amazes me how many people don't realize the need to do that.
JOHN DEERE 323D SKID STEER (A52707)
JOHN DEERE 323D...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2015 Nissan Versa SE Sedan (A55853)
2015 Nissan Versa...
