what size mower, baler
   / what size mower, baler
You can buy a used baler for $500-1000, invest $500 in parts.
You can buy a 35hp older tractor for $1500. Add $1000 for an overhaul.
Total investment, well under half of what that new baler costs. And you'll have normal sized bales, a 2nd tractor.
The little tractor will come in handy for raking the hay, maybe cutting hay. It's nice to have 2 tractors for haymaking, lot of swapping & changing implements...
A regular older baler requires about 15 hp to run the baler, & about 15 hp to tow it all around the field. Add 5 more hp to tow a wagon around behind.
More than hp, you need a HEAVY tractor to bale hay. the baler full of hay is pretty heavy, and the plunger going back & forth gives you quite a push/pull effect. Get to a hill, and that baler will shove a light tractor all over the place. CUT's just are designed for baling.
--->Paul
   / what size mower, baler #12
Grass binder £¨20-30HP£© (or Baby Chinese Baler ?)
   / what size mower, baler #13
For $11,500 you can purchase a real baler, Vermeer 5400 Rebel. Find you an old 40 HP utility tractor and you'll be making 1200 LB bales. Likely you will be better purchasing a good mower and rake and have the hay custom baled square or round. It's hard to do any more that mow & rake with even a large CUT. Buy the way a Kubota 5030 is not a CUT. A CUT is a smaller frame tractor with 40 HP or less.
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A55853)
2025 Nationcraft...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2016 Freightliner M2 106 Altec AM50 50ft Bucket Truck (A55852)
2016 Freightliner...
2016 Bobcat E85 Midi Excavator (A55851)
2016 Bobcat E85...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
