Rake What size landscape rake should I buy?
   / What size landscape rake should I buy? #1
JCS_in_KY
Kentucky
Massey Ferguson 1533
I want to get a landscape rake to use on my Massey 1533 (33 HP). What size should I get? I'm thinking either a 6 or 7 foot rake for that size of tractor. My 6' box blade clears my tractor wheels by 5" or so on either side but with the landscape rake being able to be used at an angle would I want to go wider so I could cover the tracks even when it's used at a angle?
John
   / What size landscape rake should I buy? #2
I would go with a 7' rake, perhaps an 8' rake.
I use a 6' rake with a 24hp tractor and I've used a 7' rake with a 30hp tractor without even feeling any pull on the tractor.
   / What size landscape rake should I buy? #3
JCS:
When I spoke to the NH dealership they recommended a 7' landscape rake for my 28 HP NH TC29DA for the very reason you mentioned. Jay
   / What size landscape rake should I buy? #4
Have a 7............. wish I had an 8! 28hp & 37hp.
   / What size landscape rake should I buy? #5
Yep, i'd say eight if you have no trees to squeeze between, seven if you do.
   / What size landscape rake should I buy? #6
You want to own the widest landscape rake you can AND still be able to swing it around 180 degrees.
My guess is that a 6 ft rake would be a good fit for you.
I bought a 6' rake today. It might be a little on the short side but I got a really good price on it and the dealer told me if I don't like it I can bring it back next week and return it for credit towards a longer rake. So I'm going to give the 6' a try and see how it goes, it doesn't work I'll probably trade up to a 7'.
John
   / What size landscape rake should I buy? #8
The answer depends a little on what you will be doing with it.
I have a 7' LR and it's fine on my 3320. My vote would be for a 7' LR at a minimum. If you are only manicuring an existing gravel drive, I imagine you could handle an 8' LR.
   / What size landscape rake should I buy? #9
I have a 30HP. tractor with a 7' rake,I would not go any larger.You will find that in many projects,a larger size would be a hinderence.Also if you every plan on trailering your rig(tractor,loader,rake) the size trailer(length)width of rake(6'-8') rake wheels,all have a bearing on this operation. When I trailer my rig,angling the 7' rake is impossible. Good luck with your choice!
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
Toro 880 Procore (A55758)
Toro 880 Procore...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55852)
2017 Peterbilt 567...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
