What size hydraulic hose for 7320 rear remote?
   / What size hydraulic hose for 7320 rear remote? #1
UpON
RX7320 Power Shuttle w Cab
Morning All,
I’m looking to install a hydraulic top link to use with my box blade. Found a top link at a local dealer but I’ll need to get pre-made hoses and unsure of the size to get. The 7320 is using 19gpm so I’m thinking 1/2” lines will work, but wanted to confirm here. TIA
   / What size hydraulic hose for 7320 rear remote? #2
I used 1/2" on mine but 3/8" would be just as good.
   / What size hydraulic hose for 7320 rear remote? #3
For a top link you could go as low as 1/4” if you wanted. It will not make much difference except for the speed of which the cylinder moves.
   / What size hydraulic hose for 7320 rear remote? #4
As has been mentioned most any size will work just fine. A quarter or 3/8's will be nicer to work around then a half inch hose.
   / What size hydraulic hose for 7320 rear remote? #5
I recommend 3/8" hose. Pretty much every top & side link supplier that build these units provide-recommend 3/8" hose.
   / What size hydraulic hose for 7320 rear remote? #6
1/4 or 3/8, no way 1/2.
   / What size hydraulic hose for 7320 rear remote? #7
I have 1/4" hoses on my TnT. They operate too fast for my liking. I plan on getting some restrictors to slow them down. :oops:
   / What size hydraulic hose for 7320 rear remote? #8
Why not 1/2" Kenny? I'm running 1/2. Fits and works fine. I run 1/2 on everything. It makes it easier to have everything the same size.
Greatly appreciate the support all!
I’ll probably run the 3/8” and call it done
   / What size hydraulic hose for 7320 rear remote? #10
And "single wire" will be more flexible and be plenty strong enough for most anything especially a top link.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W40T2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
