What size hydraulic hose for 7320 rear remote?
   / What size hydraulic hose for 7320 rear remote? #1
UpON
RX7320 Power Shuttle w Cab
Morning All,
I’m looking to install a hydraulic top link to use with my box blade. Found a top link at a local dealer but I’ll need to get pre-made hoses and unsure of the size to get. The 7320 is using 19gpm so I’m thinking 1/2” lines will work, but wanted to confirm here. TIA
   / What size hydraulic hose for 7320 rear remote? #2
I used 1/2" on mine but 3/8" would be just as good.
   / What size hydraulic hose for 7320 rear remote? #3
For a top link you could go as low as 1/4” if you wanted. It will not make much difference except for the speed of which the cylinder moves.
   / What size hydraulic hose for 7320 rear remote? #4
As has been mentioned most any size will work just fine. A quarter or 3/8's will be nicer to work around then a half inch hose.
   / What size hydraulic hose for 7320 rear remote? #5
I recommend 3/8" hose. Pretty much every top & side link supplier that build these units provide-recommend 3/8" hose.
   / What size hydraulic hose for 7320 rear remote? #6
1/4 or 3/8, no way 1/2.
   / What size hydraulic hose for 7320 rear remote? #7
I have 1/4" hoses on my TnT. They operate too fast for my liking. I plan on getting some restrictors to slow them down. :oops:
   / What size hydraulic hose for 7320 rear remote? #8
Why not 1/2" Kenny? I'm running 1/2. Fits and works fine. I run 1/2 on everything. It makes it easier to have everything the same size.
Greatly appreciate the support all!
I’ll probably run the 3/8” and call it done
   / What size hydraulic hose for 7320 rear remote? #10
And "single wire" will be more flexible and be plenty strong enough for most anything especially a top link.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
John Deere 1790 Planter (A50514)
John Deere 1790...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
