Rake What size for landscape rake
   / What size for landscape rake #1
jester7891
NJ-PA border on the Deleware
Kubota B7610
I have a 24 HP Kubota B7610 that I am building an orchard with. I need to buy a landscape rake (AKA york rake I believe) to clean up the area. What's the largest I can go (5ft, 6ft, 7ft etc) that will drag all the dead branches, brier bushes etc with? Thanks, Jester
   / What size for landscape rake #2
I think the B7610 would handle any of them. The limiting factor would be going through gates and in between trees and other obstacles. This is what I would take into consideration for width.
   / What size for landscape rake #3
If you're just dragging dead limbs and light brush, then 24hp should handle the 6ft rake just fine, especially if your tractor is 4x4. The thing with going to 7ft is that the implement weight begins to add up considerably because it is designed to be pulled by more powerful tractors, so it's made heavier duty. Maybe you can rent a 7ft rake from a rent all shop to see how it handles a 7ft?
   / What size for landscape rake #4
I think 6 ft is just about perfect for a B7610
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55314)
2019 New Holland...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2013 Dodge Durango Crew AWD SUV (A55853)
2013 Dodge Durango...
2018 KENWORTH T880 (A55745)
2018 KENWORTH T880...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
