What size equipment can TC29 use?
   / What size equipment can TC29 use? #1
sgarver
se kansas
NH TC29D, 640 Ford, G1800-S, Grasshopper, Jacbosen
What size of tiller can i pull with a TC29 Hydo tractor?
Blade?
Rotary Mower?
what other attachments have used with this size tractor i would be interested in knowing.
thanks for any info you have.
   / What size equipment can TC29 use? #2
With my DX 33 I use a 5 ft brush cuter and 6 ft finish mower. Works good.
   / What size equipment can TC29 use? #3
For a tiller, it's very important to cover the tracks of your rear tires. I think you'll find that your tractor tires are over 5' wide. I'd go with a 6' tiller because you can easily remove one set of tines if it is too wide. Once you have tilled your plot one time and loosened the soil, you can put the tines back on and completely cover your tracks. Most likely, you will be able to just take it very slowly and be fine with the 6' width. Having an HST transmission is ideal for using a tiller.
I was hoping a 6' tiller would work so i could cover tracks.
i think the super steer and hydo will allow me to get close and control positioning better for yard work around trees etc.
i have a 6' finish mower that came with the tractor so i figured it would work
guess it depends on the length of the grass (or weeds).
we have a farm store in town that sells King Cutter brand so i'll probably get
on of those.
thanks
   / What size equipment can TC29 use? #5
My Dx33 is not much over 60 inches. Perhaps 61. Your TC29 may be the same chassis. With just an inch over the tracks they would pretty much be covered by a tiller. I do not have a tiller so cannot give too much advise there. Something I was reading recently made me believe a 5 ft tiller would be more than enough for one of these machines. A 6 ft rotary cutter would help in getting closer to fences but weight and power required may be a bit much.
I think the 60" is probably a better fit for me!
I looked at the 60" and the 72" king kutter.. the 72 looks pretty big
around a yard and house area the 60 may be easy to get around
thanks
steve
   / What size equipment can TC29 use? #7
I have a TC29 and use a land pride 1058 with no problems whatsoever. ( 58" width)
   / What size equipment can TC29 use? #8
I have had no problems operating ~60" attachments.
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
2004 Ford F-550 Wrecker Truck (A51692)
2004 Ford F-550...
2025 AGT YC-32G (A50123)
2025 AGT YC-32G...
12 in Large Excavator Bucket (A52377)
12 in Large...
