What size earth auger bit do you use for a 4x4 fence post?
   / What size earth auger bit do you use for a 4x4 fence post? #21
I've augured big holes, suspended the post in the hole with room below, and poured concrete to slightly above grade with a rounded top surface, with great results. Mine are now almost 40 years old and look fine.
It matters how you are attaching to the posts. If you are using prefabbed panels, and you need the post to be accurately placed (like an inch or better), your hole has to be big enough to not just fit the post but also provide you clearance within which you align the post. That belongs in your radius budget.
It also matters what the soil is like. If you have roots and rocks to deal with, they can put the auger off course. You also need to budget radius for that. Of course, you can also do more with hand tools to fix that, but it's labor intensive, so your choices for placing one post might be different than for placing 100.
   / What size earth auger bit do you use for a 4x4 fence post? #22
In our country, as small as the post will fit into. We normally hit rock at about a foot to a foot and a half under the surface. Three feet down, packed with the dirt and chips that came out of the hole and you will have a post that will stay straight until your grandsons are old men.
   / What size earth auger bit do you use for a 4x4 fence post? #23
I didn't realize sitting a fence post could be so technical, drill a hole and sink that baby.
   / What size earth auger bit do you use for a 4x4 fence post? #24
I have a 9 inch and a 12 inch auger for my post hole digger. I bought the 9 inch because I thought it would dig faster on a project that I was using metal pile for posts. It dug too fast and I was spending more time pulling it out of the ground then anything else, so I took it off after a dozen holes and haven't used it again. The 12 inch works out great for everything I've need to do. If you are going to do a long fence line, and you want it really straight, you'll also need a good clamshell digger to adjust most of the holes after you've dug them with the auger. It's amazing how crooked those holes are after drill a bunch of them!!!!
I hate modern treated 4x4's because most of them will twist on you as they dry out. To save the environment, or whatever official reason the government came up with, the modern method requires a huge amount of water to be forced into the lumber. With 4x4's, the wood isn't large enough to withstand this and remain straight after drying six months after installing them. 4x6's do better, but if you want something to remain straight, you have to buy 6x6's or round posts.
Wood posts rot at the surface. A totally rotted out post will look brand new just six to 12 inches down. The cycle of getting wet, drying out, then getting wet and drying out again, over and over, is what rots out a treated post. The best way to keep a post dry at ground level is to create a slope next to the post. If backfilling with dirt, it need to come up the post and slope away. Over time, this usually washes away and you end up with a low spot next to the post that holds water. With concrete, build it up above grade so water runs away from the post. For those who are worried about the concrete leaving a small gap between the post as the post shrinks over time as the water leaves the post, the amount of water that gets into that space is insignificant and doesn't cause any issues.
I have no experience with foam. When it first came out, I looked at the cost and thought it was too expensive to bother with.
   / What size earth auger bit do you use for a 4x4 fence post? #25
2 3/8" used oilfield pipe is the way to go. One every hundred feet with t-posts in between every ten to twelve feet. I will never put another wooden post in the ground again after the wildfire of 2011 taught me a painful lesson.
   / What size earth auger bit do you use for a 4x4 fence post? #26
Please ship me 528 pieces at 10 feet per piece of oil field pipe to NC. No need to dig a hole, just drive them in. ;)
   / What size earth auger bit do you use for a 4x4 fence post? #27
That is exactly how my neighbor does it. I don't have the equipment for driving them and work solo, so it is not an option. If I thought you were serious, I know a guy that can supply the pipe. About $12 each plus a small freight charge.
   / What size earth auger bit do you use for a 4x4 fence post? #28
Been reading along and not commenting but... I just pulled 50 .40 retention PT posts that I set 10 years ago in 6" augered holes, 5 feet deep with 2 bags of Quick Crete in each and not one of them was rotted off and the Quick Crete came out with them and a quick wack with a sledge hammer broke off the hardened concrete which went back in the hole. Posts are still pristine and stacked behind the barn so from first hand experience I don't buy into the rotting or anything else. Didn't happen here and our water table is pretty high. Since then (now), I drive posts with my Shaver post driver instead of augering holes. Much easier and quicker.
Rooster Artwork (A55758)
Rooster Artwork...
Giyi 59" Vibrating Bucket (A57149)
Giyi 59" Vibrating...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
John Deere 7410 (A53317)
John Deere 7410...
NEW ROLL OF REDBAND FENCE WIRE (A58374)
NEW ROLL OF...
WACKER NEUSON LIGHT TOWER (A58216)
WACKER NEUSON...
