What size Disc Mower
   / What size Disc Mower #1
trook
North Central Mississippi
JD 5075E Cab
I need to find a way to cut the grass on the inside of a 5 acre pond dam, and I am considering a disc type hay cutter. I have a 4x4 JD 4320 with 40hp at the PTO. More than PTO hp, I am concerned about the weight hanging off the side of the fairly small tractor. My rear tires are loaded, and I have a FEL. I would estimate that the total tractor weight is around 5,500 lbs. What you think about the disc cutter, and what maximum length do you think my 4320 will safely handle?
   / What size Disc Mower #3
instead of a heavy disc mower get a belt driven 3 pt sickle bar mower. It will lay right over the bank avaialble in 9 ft bars aswell. Ken Sweet Might be able to fix you up. sweettractors .com
   / What size Disc Mower #5
Agree. I recommend considering 3ph sickle bar also. Many/most cut at steep angles(up and down), lighter weight, fast cut especially if double acting, probably less money.
I started out looking for disc mower about 5 yrs ago and ended up with sickle bar after shopping around and haven't regretted it one bit. I use it for along road, edge of fields, and along the creek.
2006 STERLING LT9500 SERIES CHEMICAL TRANSPORT TRUCK (A45333)
2006 STERLING...
Laptop Computer Mounts (A42745)
Laptop Computer...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A43004)
2019 INTERNATIONAL...
New Holland TN65S (A44501)
New Holland TN65S...
Wash Out Bucket (A44502)
Wash Out Bucket...
MIXER TANK (A45046)
MIXER TANK (A45046)
