What size cutter for an M7060?
   / What size cutter for an M7060? #51
Why does the width of the tractor make a difference on a tow behind batwing? Because "not all ground is level ?"
Huh? LD1 asked a very good question: What difference does it make [tread width] with a tow behind batwing? None as far as I can see. Any issue with "ground not being level" would be somewhat sarcastic implication of steep ground with tip over stability issues, etc. Is that what you meant? That factor seems to be inherent with the tractor regardless of whether it is towing a batwing.
   / What size cutter for an M7060? #52
How specifically is that performed?
Good one captain obvious. But you still failed to answer the question.
What does it have to do with a towed implement? Why does tractor width make any difference whether you pull a 12' batwing or a 21' batwing, or just a trailer or nothing at all?
  • Good Post
Reactions: JWR
   / What size cutter for an M7060? #53
Had a twin spindle MX-8 on my M7040
Was a perfect match
  • Good Post
Reactions: JWR
Bushhog states in the 1812 batwing manual that the inside rear wheels have a 60” width. The M7060 is 41”. I assume the concern is you could roll the tractor. I have an M7060 and want to get a Bushhog 1812 as well. Let me know if you experience any issues with stability on uneven ground.
After owning this setup for a few years now, I can say the concern is not a rollover, it's contact with the inside of the rear tires with the Bush hog in a turn. Even with my rear wheels spaced almost to maximum, I've managed to contact the edge of hitch. I never knew it until I saw the black marks on the paint. The rollover concern is without merit as the hitch on the bush hog can rotate 360 deg about the centerline axis, not to mention this Bush hog is 3,200 lbs with a low center of gravity with a hitch weight of 1k lbs will pretty much keep the tractor planted.
Overall, the 1812 is a good matchup with my 7060.
2018 XCMG CV83PD (A53317)
2018 XCMG CV83PD...
Adams 5T Pull-Type Fertilizer Spreader (A55315)
Adams 5T Pull-Type...
UNUSED FUTURE RB66-66" ROCK BUCKET (A57193)
UNUSED FUTURE...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2012 Big Tex 14ET-20BK 20ft 7 Ton T/A Flatbed Trailer (A55852)
2012 Big Tex...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
