Rotary Cutter What size cutter for a new tractor
   / What size cutter for a new tractor #1
dirtyj
Hi
I'm new here and was hoping for some suggestions.
I have about 150 acres in CRP That has is being over run w/ sweet gums. My former tractor and 5 ft deck couldnt keep up so I am buying a John Deere 5205.
This has a PTO HP of 50 and I want (thing I want)an 8 ft deck. Any suggestions? Single blade 7' maybe? The sapplings currently are 2-3" around and w/ this machine I on't plan on letting them get this big again.
Thanks for any advice.
   / What size cutter for a new tractor #2
I believe the rule-of-thumb is 5hp per foot of cutting width, but your best bet is to check the HP requirements for the various cutters you may be interested in. Most manufacturers list those requirements on their Web sites.
Good luck.
Steve
   / What size cutter for a new tractor #3
You've got plenty of power now.
All I'll suggest is to look at pull behind cutters as well as 3PH type. You can use a wider pull type with the same PTO HP.
   / What size cutter for a new tractor #4
I think I'd be lookin' at twin-spindle 10 foot pull-behinds
//greg//
   / What size cutter for a new tractor #5
I agree with the pull behinds ... 10' should be good
   / What size cutter for a new tractor #6
We use a 10'6" Woods DS1260 pull behind, but I believe a 50 PTO would be marginal and would probably go with an 8' dual spindle made by Woods or any other good brand. "Builder" uses an MX8 with a hydraulic offset that is really nice.
Thanks for the helpul responses!
John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
John Deere Gator...
More info coming soon! (A50322)
More info coming...
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
Massey Fergusson 4253 (A50120)
Massey Fergusson...
2017 Terex Warrior 1800 Screener (A50322)
2017 Terex Warrior...
