What size chain would you use?
   / What size chain would you use? #1
timster2
Platinum Member
North East PA
Kubota BX2230 & B2320
I am thinking of building one of these to trim some trees. What size chain do you think I should use?
   / What size chain would you use? #2
5/16 Gr 80.
You probably won't see that in the USA..unless it's someone stealing cable.
   / What size chain would you use? #3
5/16 chain should be fine. 3/8 is bigger but i don't think necessary. i use 5/16 on my 3ph winch and it is a 7000 lb winch. interesting setup for a bucket lift.
   / What size chain would you use? #4
It's interesting that they triple the chain on each side, while apparently leaving nothing but some sheet metal at the edge of the barrel to hold all the weight. :laughing:
   / What size chain would you use? #5
I certainly hope you are just kidding:thumbsup:
   / What size chain would you use? #6
I would use a plastic container and hemp rope. But make sure you use a hard hat in case you fall it will protect you. Bozeman bucket brigade !
   / What size chain would you use? #7
Depending on how pressed one is for time, could grow the hemp in the bucket..........then make the rope:thumbsup:
Just watch out for heat seeking helicopters:laughing::laughing:
   / What size chain would you use? #8
Brings to life the meaning of the term "man bucket"
   / What size chain would you use? #9
I would use a plastic garbage can that has molded handles and Yellow Plastic Safety chain that would be OK because it's "Safety Chain" . . .John
   / What size chain would you use? #10
As stated 5/16 grade 80 would be more than enough as the weak point is going to be the sheet metal of the 55 gal drum. That would likely fail way before you broke the chain.
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
