What size chain should I use to pull large trees
   / What size chain should I use to pull large trees #31
Witnessed that one time with a 3/4" nylon rope (not my set-up, but was there, nevertheless). When it broke, it was unbelieveable the damage that was done. The tree was near a house. The rope snapped, went back past the tree on the side opposite the chainsaw man, and through the side of the house (wood siding, 1/2 sheathing plywood, and drywall). It was a killer that missed everyone. The guy in the truck didn't realize there was that much tension in the rope as the truck just kept moving forward. He thought that when the rope became taught, that he would quit pulling. But it just kept stretching. The knot in the rope at the pulling end helped do the damage to the house.
I've heard of these ropes being used in rope-pulling contests, and when they break, the rope recoiling tears off fingers and does a lot of damage to the rope pullers. Don't think they use them anymore. The built-up tension is handy when pulling some things, as mentioned to have tension against the tree when pulling. But its handy only as long as the strength of the rope (at it's weakest point) isn't exceeded.
Never again will I pull anything with a nylon rope, and will only use them to tie things up (or down).
slowzuki now your just poking fun at South Texans you said it was easier in the winter to get cable around tree because you could dig a tunnel. LMAO I'm assuming your telling me that you burrow through the snow. We only get snow at night once or twice a year and by morning it usually melts, every ten years or so we actually get a snow that will last a day or two but even then it's usually only a couple of inches. I think rather then wait for the next snow I'll use my FEL as was suggested by ? as I'll get a lot more trees moved this way rather than waiting for it to snow so I can burrow under it.
Thanks for all the great info I'm looking into the chokers that sounds like a great way to hold the logs in place as I can see the chain would probably slip off in the half mile skid to the house. Steve
   / What size chain should I use to pull large trees #33
</font><font color="blue" class="small">( Forgot to attach the picture. /forums/images/graemlins/smirk.gif )</font>
Those cable chokers look neat, but I'm a little lost as to how they attach. I assume you thread one of the cable ends around the tree butt. Then through the red clampy thing so it holds somehow?
What do you do wth the other end of the cable, as it appears rather smooth - other than the Cat models with an eye. How do you grab the smooth cable with the pulling tractor?
It just looks too simple to me - and I like simple, I'm interested in these! /forums/images/graemlins/smile.gif
--->Paul
   / What size chain should I use to pull large trees #34
LOL Texas, hmm, the ground gets magically softer in the winter! Re the cables vs chain chokers they both work well, many loggers carry both. It gets expensive to carry long chain chokers I think but I feel the chain is easier to work with.
Chain also slips into notches in small logging winch butt plates much easier if you have one. This is used when you winch in multiple hitches to skid out.
   / What size chain should I use to pull large trees #35
Hi Paul
Sorry for the small picture but that was from Bailey's website. I will take some close up pics with my digital showing how these work, the ends etc and post them tomorrow. Just check back tomorrow night.
These work great and are firm enough to slide under a downed log. The tip is swedged and it feeds through dirt, snow etc. Chains are difficult to get under a log and tend to tighten onto the log when you skid them. These chokers come undone easy and are light and easy to store.
Bailey's has different options for ends, cable diameter, lengths. I have the small micro bell with a heavy duty eye. I think it is 12' and it cost about $15 plus shipping. I believe it was under $20 total. I can slide this around 3-4 logs and cinch all of them together and skid the bunch to the decking area.
Check back tomorrow night and I will have it posted. /forums/images/graemlins/grin.gif
   / What size chain should I use to pull large trees #36
Chain and wire rope are dangerous. I only use short length of chain around log for abrasion resistance. From there to tractor it's Spectron12 rope. Very light with virtually no stretch. Sure beats dragging heavy chain around and I can coil it uo and hang it from my ROPS without hurting paint or my back Check spec, but I think 1/2" is rated 12Klbs.
   / What size chain should I use to pull large trees #37
I've never heard of such a rope. What is it made of? I would suppose that it too would be "dangerous" if used beyond its ability as is most stuff. I have a nylon strap rated at over 40,000 lbs. It is derated as it gets dirty which apparently degrades it's strength.
   / What size chain should I use to pull large trees #38
<font color="blue"> I've never heard of such a rope. What is it made of? I would suppose that it too would be "dangerous" if used beyond its ability as is most stuff. I have a nylon strap rated at over 40,000 lbs. It is derated as it gets dirty which apparently degrades it's strength. </font>
Only if you were using it to hang something too heavy over your head. I've seen the stuff break and it just lays there with no recoil. It's made from a Kevlar type fiber. It's marketed in US by Sampson Rope. Slings are notorious for stretch and are commonly used 'round here for "snatching" stuck vehicles. You would lose a bumper with this rope.
Do a google and you will be enlightened.
   / What size chain should I use to pull large trees #39
Reading this thread brings back fresh to mind the litany of patients which I had the privilege of caring for while directing the hand/microsurgery and burn units at the Yale Univ. Med. Ctr. It's fairly safe to say that none of these horrific injuries of all imaginable "amputateable" body parts was self-inflicted or even remotely anticipated by the patient. They were all "accidents."
While we all try to be safe all of the time, unanticipated life changing events do happen. If you are witness to a traumatic amutation of any body part, following these guidelines should ensure that the patient has the best possible chance to maximize a functional recovery:
<ul type="square">
1. First, be certain that the patient is receiving proper first aid/medical attention--the "ABCs" of Airway, Breathing, Circulation. Apply pressure to stop bleeding at the site of the amputation. Be aware that tourniquets can cause more damage than good.
2. Retrieve the amputated part.
3. Do NOT try to clean, wash, or scrub the part. The microvessels at the cut end are very easily damaged, and that additional damage may prevent a successful replantation.
4. Place the part in a clean, DRY sealable ZipLoc type baggie. For larger parts, use clean plastic garbage bag if available. The amputated part will not dry out if sealed in a baggie. Do NOT add water, or any other liquid to the baggie. None of those materials is physiologic, and they will all produce swelling and more damage of the critical microvessels. Even soaking parts in "physiologic saline solution" used in IV's has been shown to cause swelling and damage of the "stump" microvessels. These vessels are the essential elements needed by the microsurgeon to re-establish circulation, and any additional damage may preclude a reattachment. Milk has been advocated for soaking knocked-out teeth (w/o strong scientific basis). Replacing lost teeth, however, does not involve any microvascular surgery, so the milk is not harmful in that scenario.
5. Place the sealed bagged part in a container with WET ice. Snow is good, too. A styrofoam cup or a cooler is fine. Never use DRY ice. In the absence of blood circulation, dry ice will rapidly cause severe frostbite damage to the amputated part and may well render it unsuitable for reattachment.
6. Be absolutely certain that the amputated part accompanies the patient to the hospital. Alert the transport personnel, EMTs, etc, and physically hand the part to one of those in charge. Yes, we have had to send someone back to the scene to recover the "forgotten" part, and not a rarity either. It's easy to understand though, in a situation as emotionally charged as these often are. [/list]
Bottom line: be as safe as you can out there. However, if bad stuff happens, try to maximize the potential for a functional recovery by following these guidelines.
   / What size chain should I use to pull large trees #40
3/8ths should be strong enough. I use a Farmi winch and use the 3/8ths on the big ones 2' to 3' on the small trees which is most of them I use 1/4in boron chains both 80 grade. I've had trees hook on stumps and skidded some big ones 3'+ down a 1/4 mile rock strewn road. No breakage ! Cable chokers look like slinkys with barbs after much use.
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
