Tires What size chain for B7510 turf rear tires?
   / What size chain for B7510 turf rear tires? #1
easygo
Maine
Kubota B7800
I started looking for a set of chains for my 7510 rear tires (TURF TIRES). I have been looking for an excuse to get chains and now it came up. I will do some logging pretty soon and want chains on for that, because of some soft spots on the logging road.
I want to get the work done before hunting season so I don't make it on someone's "I'v shot that too." list.
I looked at Tirechains.com and found that I would like to get the two link spaced ladder design. The only similar size to my rears was the 33-12.5-15 for a little over $200. Would that work as far as the size concerned?
If you have any other recommendation in the $200 or less range it would be much welcomed.
I mean I know they are the size for the rear tires, but anyone experienced clearance issues or problems with proper fit? I read about chains here and those seem to be the issues people encounter with them.
   / What size chain for B7510 turf rear tires? #3
I'm also going to get chains for my B3030 so that I can snow plow my very steep driveway this winter. Tirechains.com has the size I need for both the front and rear R4's. My only question is if there will be a clearance issue between the rear tire and the fender. It looks like there is only an inch or so. The service manager at my dealer recommended that I add the wheel spacer kit to get more clearance for the chains. It would also make the tractor more stable with the additional 3" of width. Does anybody have any thoughts or experience with this?
Ace3,
I ended up getting a a set of rear chains from a dealer in my region for $180. It looks the same as the 2-link spaced ladder design on Tirechains.com. If you go with that it might fit within the little clearance you have, but you probably want to do a search on that or start a new thread. I recall reading discussions about the clearance issues on the 3030 and people suggested resolutions as well.
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2012 RAM 5500 (A52472)
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
Kohler Diesel Generator (A47384)
Kohler Diesel...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
